Old 05-04-2013, 11:59 AM
teamcanada's Avatar
teamcanada teamcanada is offline
Boat: 2013 Mastercraft X30
Kids Surf boards
Looking for a good surf board for my two daughters (8 and 11). They already wakeboard fine but want to surf with mom and dad. Tried the phase 5 scamp but it was to slippery. Any other suggestions?
Thanks.
Sent from my iPad using Tapatalk HD
Old 05-04-2013, 12:08 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Smaller is better for lightweight kids. Try anything 4'4"-4'6" long.
You can contact Brock at Doomswell boarding. I know he has made some custom boards for kids. They are around $500-$700 depending on how custom. He can put in as many fins as you need. He uses futures fins too so changing it up will be easy to get them from any surfshop.
4096926363
He is making me a custom 4'5" right now.
Sent from my HTC VLE_U using Tapatalk 2
1 Corinthians Chapter 13 - 11
Old 05-04-2013, 12:13 PM
ttu's Avatar
ttu ttu is offline
might try getting in touch with woon. he sells a few different brands of boards and can give you a good idea of what to look for.
Old 05-04-2013, 12:17 PM
kgrove kgrove is offline
Boat: 2011 X-25
You'll run into two problems for kids boards... The boards that are the least slippery and have the largest fins to aid in tracking tend to be larger with too much flotation for kids to get up easily. The boards that are low enough in flotation for the kids to dig their heels in and flip the board to their feet to get up tend to be skim style board which slide out from under kids when they don't yet know how to edge and control the board.
You may have to go with the smallest surf style board you can find, make sure it has large fins, and then really work in the start technique as the board will probably float too well for an easy standard start.
Old 05-04-2013, 12:56 PM
teamcanada's Avatar
Thanks. I have an inland swallow v2 and thought the ooze would be good with the quad fin. Nor sure though. May be too buoyant.
Old 05-04-2013, 01:56 PM
Boat: 2011 X-25
It might be buoyant enough to cause a couple problems... depends how persistent your kids are trying different techniques. My kids struggled with a Blue Lake until they were 12-13, but my kids also are prone to giving up at the first hint of failure.
The trick will be getting the board's trailing edge to sink just enough to get the board to flip up and stick to the bottoms of their feet without having to hold the board with one hand. It will take some effort on their part and coordination with the driver. Especially while learning, most kids struggle keeping the board perpendicular to the boat so it's a real balance between the driver moving quickly enough to keep the kid from getting sideways and moving slowly enough to not surprise them or pull them off balance.
