Old 05-03-2013, 08:30 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
1990 Prostar 190 / Ford/Indmar 351w GT40P:
length : 19' 0" = 5.79 m
width : 80" =2.032 m
weight w/o fuel:2.200 lbs = 998 kg
fuel capacity: 25 gall = 94.6 l
engine oil: sae 30 /api sf 4-3/4 quarts = 4.5 l 10w30
transmission oil: dexron ii or iii 2quarts = 1.89 l (any type except f)
firing order: 1-3-7-2-6-5-4-8
spark plugs (for gt40 heads not stock E7's):
btfm3m /.035"
hotter awsf52c 106 / 766 / 606
hot awsf42c awsf42c-6 765 / 5245 605
stock awsf32c 104 / 764 / 5144 / 5164
cold awsf22c 103 / 5143 / 5243
bosch super - 7580 (hr9dcy)
autolite - 764 (ap764 for plat, app764 for double plat)
champion - 401 (rs14yc6)
motorcraft awsf32c
ngk standard bpr6efs
Modifications:
http://www.latemodelrestoration.com/
gt40p heads (best improvement along with the prop)
LTP-66879 roller rocker arms, aluminum, 1.6 ratio, 3/8 stud mount, small block ford, set of 16 x1
http://www.skidim.com/
rk122014 starter kit lh 302/351 permanent magnet
edl-2181 intake manifold performer 351 w
rn0120-1 renew kit 4160 holley, 351, 350, 5.8
rp173072 breakerless ignition kit 87 up (huge improvement, no more points, remove resistor)
r117004 coil ignition electronic
427204 telssc6117 safe-t steering cable only 15’ (apparently some prostars that year use 17')
http://www.summitracing.com/
CCA-CL35-242-3 cam & lifter kit, xtreme energy , hydraulic flat tappet, 351w, 224/230 duration, .510"/.512" lift x1 (haven't put it in)
PRO-302-001 proform ford racing licensed aluminum valve covers 302-001 (need spacer exhaust manifolds to create a bit more space)
pro-67235 adj vac secondary housing (nice if you want to be able to adjust sencondaries on the fly)
ult-9014-045 optima yellowtop deep cycle 12 volt batteries 9014-045
SPW-1450300 Superwinch S Series Winches 1450300 (got tired of winching)
http://www.fordracingparts.com/
m-9600-l302 round air cleaner assembly
http://www.overtons.com
item 74334 sahara 6 gauge set
http://www.perfectpass.com/
perfect pass stargazer for carbureted applications (wife drives through the course)
http://www.nettleprops.com/
Acme 541 Propeller 3 Blade 13 X 12 LH 1" (best improvement along with the heads)
http://www.amazon.com/
Lokar XED-5005 Black Stainless Steel Housing Dipstick with Black Fittings for Ford 351 Engine (nice and flexible)
Old 05-03-2013, 10:33 AM
BARE5's Avatar
BARE5 BARE5 is offline
Boat: 1995 PROSTAR
Wow, wish there was more like this post. Great note taking.
Old 05-03-2013, 11:42 AM
Impressive list.
Are you using an automotive air cleaner in place of a flame arrestor?
Old 05-03-2013, 12:12 PM
Wouter's Avatar
hum, yes, good eye, I am using an air cleaner in place of flame arrestor (those things look so wimpy...)
Old 05-03-2013, 01:01 PM
Are you using the K&N flame arrestor element with this?
Old 05-03-2013, 01:06 PM
Wouter's Avatar
nope; just the air filter that came with the ford racing assembly. Motor box doesn't have insulation and gives just enough clearance (if that's why you are asking)
Old 05-03-2013, 01:12 PM
Wouter's Avatar
I see. Not coastguard approved unless it's the K&N Marine Approved per SAE J1928 Flame Arrestor Standard... No USCG over here: wonder if that's riskier in case of backfire? Myabe time to get the K&N one...
interesting link: http://www.knfilters.com/marine/flamearrester.htm
Old 05-03-2013, 01:15 PM
My thought was more to a backfire and the flammability of the paper element. My 69 Mustang with a tunnel ram backfired through the carbs once and melted down the low profile foam element air cleaners. Fire under the engine cover is never good.
Old 05-03-2013, 01:19 PM
Wouter's Avatar
It's been on there for a while now but you're absolutely right... good catch, hadn't occurred to me
pix of the stang?
Old 05-03-2013, 01:31 PM
pix of the stang?
Any pics of the engine with the air cleaner? I would think that with an approved filter it would be acceptable to the Coast Guard.
