Old 02-26-2013, 05:30 AM
youngman youngman is offline
Boat: Mastercraft, prostar 190, 1994, 350 indmar TBI
Do I need a new throttle cable?
Hi, own a 1994 prostar 190. When I move the throttle lever forward it goes into gear as normal, but when I try to accelerate up to speed nothing happens until the lever is almost as far as it goes. In this position the boat would normally be doing about 44mph but now is only doing about 20mph. Everything looks ok behind the lever beside the drivers seat. Has this happened to anyone, or any ideas on what I should be looking for. Much appreciated.
Old 02-26-2013, 07:45 AM
mayo93prostar mayo93prostar is offline
Sounds like your throttle cable may have come loose at the "carb". Check that first. Second is to check the cable connection behind the throttle lever. If it is moving some, I doubt you need a new cable but you may. I assume you have fuel injection in a 94.
Old 02-26-2013, 03:42 PM
Shooter McKevin's Avatar
Shooter McKevin Shooter McKevin is offline
Boat: 2000 Prostar 190, LTR 330
If you have perfect pass then I'd say it's the tension knob (or whatever perfect pass calls it). Mine does that occasionally and the knob needs to be re-wound manually.
Old 02-26-2013, 04:46 PM
I had the same issue in 2012, we replaced a little piece in the throttle assembly itself... I'm not sure what it's called... Jeff Knight @ Texas Mastercraft will know what you need and what it's called. My throttle is perfect now.
Old 04-29-2013, 05:50 PM
Epimetheus Epimetheus is offline
Boat: Mastercraft prostar 190 1996
Update?
Did you get to the bottom of this? I have the same problem and I figure the cable is stretched. I adjusted it as far as I could but wasn't enough. So I figure a new cable will be the fix?
