Old 04-27-2013, 04:15 PM
gruvnfunk's Avatar
gruvnfunk gruvnfunk is offline
Boat: X-Star 2000
How to power the auto-bilge while at dock.
I have X-Star 2000. I leave it in the water, not on a lift (do not criticize... just sent this poor student money so I can buy a lift) at my friend's dad's house during the summer. I go out once a week usually but I usually do not see the boat in between when I go out. If it rains I have to make a trip over there to run the bilge. I am curious what recommendations you all have for me to power the auto-bilge without draining the battery so that I do not have to make special trips just to run the bilge. The ideas I have come up with that I would either like your advice on how to do it and what hardware I need OR I am also looking for more suggestions:
1. Connect the boat electrical system to the shore. What hardware do I need in order to be able to "plug" my boat into an outlet on the dock. How much (approx) would this cost?
2. Is there any solar alternative to hook into the electrical system that is reliable to keep the batteries charged.... I doubt it would be reliable.
I currently have two batteries a Group 24 & Group 27 on the boat that run through a battery switch (1, 2, ALL, OFF).
Old 04-27-2013, 04:22 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Yes there are solar battery chargers, this is probably your best bet and most economical use a solar charger and leave auto bilge on, http://www.amazon.com/s/?ie=UTF8&key...l_2m0d4h2gf3_b
Old 04-27-2013, 06:49 PM
petermegan's Avatar
I don't see why you couldn't run a step down transformer from your 110
V down to 12V. Get one slightly bigger than bilge pump requires and a regulated one. Should be cheap.
Old 04-27-2013, 07:07 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
How about a regular battery charger/maintainer like the ones ProMainer makes. Sems like a simple solution that has benefit beyond just topping up the batt for bilge pump power.
Old 04-28-2013, 08:34 AM
jakethebt's Avatar
jakethebt jakethebt is offline
Boat: '96 Prostar 205 LT-1
I agree, a solar battery charger and leave the auto pump on.
1996 Prostar 205 LT-1
Old 04-28-2013, 09:09 AM
I wouldn't think that a bilge pump set on auto would significantly drain your battery in a week. Is your boat covered?
Old 04-28-2013, 06:04 PM
petermegan's Avatar
I would be worried that if a leak did occur (exhaust hose and you are still a goner) that it would flatten the battery and then drown it. From that perspective I can understand the OP and a Solar charger would not keep up unless it was a pretty decent size.
Have Fun
auto, bilge, bilge pump, electrical, power
