  #61
Old 04-26-2013, 06:09 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
Place pressure plate springs and greased dowel pins.
Old 04-26-2013, 06:14 AM
Wouter's Avatar
Place your new reverse clutch plate assembly 90 and 91. Bronze goes in first, then steel, then bronze again (no picture of last plate).
Old 04-26-2013, 06:20 AM
Wouter's Avatar
Next comes reverse clutch plate 92. Align plate half moons with dowel pins so that springs correspond with clutch plate holes. The plate should drop and sit almost flush with case.
Old 04-26-2013, 06:29 AM
Wouter's Avatar
Place gasket 97.
Place sealing ring 96 (I had forgotten this, that's why you still see it next to the blue screwdriver at bottom right of next pictures but you should place it now)
Old 04-26-2013, 06:32 AM
Wouter's Avatar
place forward and reverse adapter 99. Bolt with torque wrench 27-37 lbs-ft. Again 96 should be in by now.
Old 04-26-2013, 06:33 AM
Wouter's Avatar
Place woodruff key 65.
Old 04-26-2013, 06:35 AM
Wouter's Avatar
Place pump drive gear 101
Old 04-26-2013, 06:37 AM
Wouter's Avatar
place pump gasket 103
Old 04-26-2013, 06:41 AM
Wouter's Avatar
At this point I realized I forgot to place sealing ring 96 (sitting under the blue screwdriver) So I worked backwards, removed 99 and placed it.
Old 04-26-2013, 06:50 AM
Wouter's Avatar
Place pump housing 104 and wrench to torque 17-22 lbs-ft. The pump housing has to be placed in the same position as when you dis-assembled (two positions are possible according to your engine's rotation) Make sure you get this right. If you don't remember check pictures if you took some or check manual and place according to your engine's rotation direction.
