Old 04-21-2013, 09:36 PM
Rockman's Avatar
Rockman Rockman is offline
Great progress! Keep it up! Boat will look new in no time!
I like how the brackets came out after the blasting!
Old 04-21-2013, 09:53 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
[quote=NorthCentral Customs;927723]Started to mess around with buffing the other day. Here is what I got so far.
Faded
What did you use to buff??
Old 04-21-2013, 10:16 PM
f925's Avatar
f925 f925 is offline
Boat: 1990 Maristar 240 SC
That's looking good! Sounds like you got a solid deal on that sucker! Looks like a case of MCOCD.
Old 04-21-2013, 10:59 PM
jhall0711's Avatar
Boat: None
Was curious what you found when you removed pin stripes. I heard that sometimes they were used to help cover imperfections in gel seams. Did you see any of that?
Old 04-22-2013, 11:36 AM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Looking good. Keep the progress pics coming.
Old 04-22-2013, 11:59 AM
aquaman's Avatar
aquaman aquaman is offline
Boat: 93 Barefoot 200 Yamaha 225F
Good looking boat.
She should buff out nicely.
How many hrs on the engine ? compression ck ?
Old 04-22-2013, 10:49 PM
NorthCentral Customs's Avatar
NorthCentral Customs NorthCentral Customs is offline
Boat: 2003 197 35th Anv., 1991 Mastercraft ProStar 200
Did some sanding to night. Dry sanded 1500 and 3000
1500 side
Top sanded 3000
1991 ProStar 200
2003 197 35th Anv.
1976 SnS restoring
1977 SnS restoring
1979 SnS restoring
1981 SnS restoring
Old 04-22-2013, 10:50 PM
No real imperfections on this one.
1991 ProStar 200
2003 197 35th Anv.
1976 SnS restoring
1977 SnS restoring
1979 SnS restoring
1981 SnS restoring
Old 04-22-2013, 10:54 PM
Originally Posted by aquaman View Post
Good looking boat.
Not sure on the hours. The outboards did not come with hour meters but I bought one to install. Looking for a location to mount it. If any one has a pic of the same dash or can tell me where it is located would be appreciated. I didn't do a compression test but the boat was always serviced at our local MC Dealer.
1991 ProStar 200
2003 197 35th Anv.
1976 SnS restoring
1977 SnS restoring
1979 SnS restoring
1981 SnS restoring
Old 04-23-2013, 11:28 PM
Got master cylinder today. Installed it in the hitch and bleed it out. Pulled the brakes off and found out that they where shot and never adjusted. Pull the wheel cylinders to see if they where ok and one hand good fluid and one was like mud. So new wheel cylinders, brake shoes and having the drums turned. Might buy a complete brake setup with baking plate because buying the parts separate are more expensive.
1991 ProStar 200
2003 197 35th Anv.
1976 SnS restoring
1977 SnS restoring
1979 SnS restoring
1981 SnS restoring
