#3071
Take the boat out of the garage, run it, put the boat back in the garage. If it was work for Sodar, it was work for me too!
![]() That's why you spend all that time over the winter working on the boat - so it is ready when you are. |
#3072
Drilled 6 holes in a perfectly good boat...
![]() Used the magnet method the guys at wakemakers recommended and worked perfect! Now have 3 each 1" inlets for the new ballast system. Electrical done, bronze valves & fittings installed. Just working on the hose connections now. Will snap some pic when i get close to buttoning it up. |
#3073
#3074
Got alot done in the last week...here are a few pics...alot of items in process also...
Got the platform brackets and vent covers back from powdercoater...
Looks awesome... who around here does that?
Installed my new speakers with new speaker wire and put the plugs in where heater fittings were. Took some measurements for fresh air exhaust and muffler delete
Tapatalk |
#3077
Got the old skid pads off and cleaned the fenders...just followed someone else's suggestion of using wd40 on the glue...spray and wait 10 minutes, then scrape off with a razor blade...easy job.
@ Rockman:
Like the powercoating. I need to do all of mine.
1991 ProStar / 351W with 1:1 Velvet Drive |
#3079
Finally got around to getting the insulation installed on the doghouse...scraped all of the old glue off as in the first picture, had one side of the old insulation complete, so I peeled it off to make templates and then installed the new insulation. Now just trim and tape seems and then work on the cut outs for the cup holders and vent.
Not sure...I sent them out to a place that my wife uses for their display towers.
Thread Tools | |
Display Modes | |
