05 X Star Tower Breakdown.. How To.
I have searched and searched, and found one thread of a 6 point how to... But no pictures of a tower broke down sitting. I even looked on Youtube.
I know loosen front pins, and pull rear pins, then tilt back to transom. But it said be sure to spin your Tower Racks, but didnt say In or Out. |
How about just a photo of tower broke dwn... Seems like back half should get flatter
spin your tower racks to where the forks would be facing up when you fold the back of the tower down.
-Aric LONE STAR MASTERBASH 2018 Details released eventually 2016 X30-Wetsounds galore 2017 Misty Harbor Tri-Toon 1985 S&S- For Sale |
I've never folded mine, but if you look at the front hinges it will only allow the tower to fold forward. I assume you remove the 4 large knob screws (2 on each side) at the rear tower legs and fold the entire tower forward? I would rotate the board racks in first.
I was njskier on here. |
I pulled the two closest to bow on the down slope bars to front. Then I pulled the two in the cockpit closest to bow and loosened the back two. Then w help pushed toward transom all came apart but it stuck up to much once folded on back deck. It may be my tower speakers holding up 4" since they hit first. Just figured the back portion would get Windshield height at least but no such luck... I found
It should fold forward using the hinges that are about windshield high, then fold the rear legs toward the center of the boat.
Different year, but basically the same thing...
onewheat 2013 X-25 |
Will do on pics.. I ended up taking back half off just to get in garage for deep clean.. based on this pic its my speakers keeping it to much in air
We us a small hard sided Coleman cooler and sit it in the walk thru and let the tower (at about the tower tow point) rest on the cooler. |
#10
[quote=Jerseydave;926927]I've never folded mine, but if you look at the front hinges it will only allow the tower to fold forward. I assume you remove the 4 large knob screws (2 on each side) at the rear tower legs and fold the entire tower forward? I would rotate the board racks in first.
You do not want the weight of the tower on the front legs............
MISS "B" HAVEN 2007 X2, Indmar 350 MCX (Sold) OJ 522 14.75 x 15.5 Tugger: 2014 Ram 1500 Crew, EcoDiesel http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
Thread Tools | |
Display Modes | |
