#511
I would love to sand and finish yours. I happen to be in the flooring business so sanding wood floors is my passion. This is pretty familiar stuff for me. I just sanded it down with 80 grit orbital palm sander. I used watco teak oil finish from menards. Like someone said in a previous post the lower grits like 80 or 100 will leave the pores open for the oil to penetrate better. If 80 doesn't cut off the old stuff try 60 then finish with a finer grit.
#512
Sanded with 60,80,120, then star bright teak oil. Now I understand.
And all the cars are covered with sawdust. Oops!
https://badges.fuelly.com/images/smallsig-us/302328.png 1988 prostar 190 SOLD 2001 Prostar 209 SOLD |
#513
Oh yeah!!!!! Looking dang good man!!!
#514
After getting off of work yesterday, I pulled the platform and started sanding. Here is what I learned.
1. Progress may be slow due to repeated trips to the fridge for a fresh beer. a. Solution - place beer in cooler and take to where you are sanding. 2. It's going to take longer than you thought. a. Buy extra beer before beginning. 3. Any glue used in the original assembly has probably failed by now. Disassemble as much as you are comfortable with, it makes the sanding easier. 4. As much time as I spent sanding; next time I may just run it through my thickness planer. 5. See items 1 & 2. This is early in the process.
Being on the water is best, but when I'm not on the water I'm on TT. 2002 X Star Sold - 76 S&S |
#515
Just got around to pulling my teak in prep for the summer here. One of the pieces my support bracket is attached to looks about on its last leg.
Any good tips on where to get a replacement piece? |
#516
Im still waiting on my replacement piece for my support bracket that I ordered last Sept (2012). Guess I should call them!
2002 Maristar 230 VRS |
#517
Another option for a board or two is fleabay.
#518
I have a little question.
For redoing after a season do you sand of with a 1000 grid or somethin and wich grid to don't make it slippery? Or do you just oil again? |
#519
I did it first with a 240 grid and cleaned it with a cloat with aceton let it dry an than oiled it looks good again, like new
#520
don't have pic of it but when i got it mine back from getting interior redone they said the put tranny fluid on mine, gotta say it never looked better.
Thread Tools | |
Display Modes | |
