Old 09-04-2012, 09:37 PM
It wouldn't take a lot of exposure to saltwater to make the engine look like this. I suspect you will have to go the full engine rebuild route, but sounds like you need to pull that engine and let the professionals do their thing. Saltwater exposure to the electrical components may be your largest hurdle. Good luck.
Old 09-05-2012, 12:04 AM
thanks for workin' on bringing her back to life...
Old 09-06-2012, 05:49 PM
lazyade lazyade is offline
Boat: '92 190 Prostar and the new project '05 X Star (Indmar 350 MCX)
I'll do my best!
'92 190 Prostar 260hp Indmar.
Old 09-10-2012, 11:38 AM
Boat: 1997 prostar 205 lt1
Where is the boat located? The heads can be brought back pretty easy with a valve job and some oversized valves and reamed guides. As long as they are not cracked the heads can really take some abuse and still clean up because they don't have any internal oil passages the oil is fed through the push rods. The block could be a whole different story if it went under while running the rods may be bent and if the block won't clean up with less than a .030 over bore you need to pitch it. The cam is toast if the lobes have any corrosion on them at all, the crank is pretty stout and can be ground on both ends if the corrosion is just light surface rust. Also if the crank front and rear seal areas are badly pitted you can have the ends sleeved but at that point you should just look for a rebuildable core. Pull it apart and see what you got. maybe you'll get lucky but things don't look too good at first glance.
Old 09-14-2012, 10:44 PM
DH9441 DH9441 is offline
Boat: 1985 MC S/S
Dang...what the heck happened to that thing.....it's only an '05.
Old 09-16-2012, 08:41 AM
I think the previous owner had the back end submerged at some point. We're getting a new long block, cleaning her up and hopefully bringing her back to life.
Old 03-21-2013, 03:47 AM
46Chief 46Chief is offline
Any updates?
Old 03-29-2013, 01:56 AM
ranger098 ranger098 is offline
Boat: 2004 mastercraft x2
yeah... updates!
Old 04-02-2013, 04:51 PM
I started a new thread some weeks ago on the updates, have a read through here: http://www.mastercraft.com/teamtalk/...ad.php?t=52162
350 mcx seized
