  #2771
Old 04-01-2013, 04:29 PM
Ironhorse Ironhorse is offline
Boat: 2008 Mastercraft X14 w/ LY6
You are ready for oil Rockman!!
Old 04-01-2013, 05:08 PM
Rockman's Avatar
Rockman Rockman is offline
Thanks!
That's what I was thinking...It seemed the cleaner and brightener would be used had I NOT sanded everything down already.
I put in enough hours on this already and do not want to mess up the process at this point.
So I figured I would ask...good thing is that going forward, maintenance will be easy.
Old 04-01-2013, 05:47 PM
Boat: 93 190
John 3:16-18
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
Put a power outlet in the small compartment behind the rear seat - so I can plug in my inflator. Oh yeah, I pull inflatables! And proud to do it!!
Old 04-01-2013, 06:44 PM
BrooksfamX2's Avatar
Boat: 2007 X2
Same here.
I put a converter in to power a 110v pump. Fills tubes twice as fast.
MISS "B" HAVEN
2007 X2, Indmar 350 MCX (Sold)
OJ 522 14.75 x 15.5
Tugger: 2014 Ram 1500 Crew, EcoDiesel
http://www.crowniehq.net
Old 04-01-2013, 07:10 PM
Rockman's Avatar
I'd wash it and let it dry for a day or so. No big deal. I was a teak fan for many years until I went with the mineral spirits and linseed oil. My opinion and experience is that teak oil is a thing of the past for me....
Otherwise, I'd put a straight shot of teak (light application) let it dry for half an hour, wipe it down to remove excess, let it dry for a day or two, then repeat once more or until you find the shade for which you are looking.
Good luck
$0.02
Thanks!
Old 04-01-2013, 07:16 PM
drschemel's Avatar
Originally Posted by BrooksfamX2 View Post
Same here.
I put a converter in to power a 100v pump. Fills tubes twice as fast.
I thought about an inverter, but I'm a little queasy about using high voltage around water and passengers. As long as it has a good ground fault circuit, I guess it would be ok.
Old 04-01-2013, 07:18 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: 40th Anniversary X14
Originally Posted by Rockman View Post
Thanks!
John I am a fan of the linseed oil/ mineral spirit formula too. I spend years using #1's method and that is way too much work and doesn't hold up. (unless you forbid everyone from using it)
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 04-01-2013, 08:23 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
X2......on the 80/20 mix. seems more durable
---Animal house
Old 04-01-2013, 09:28 PM
reftech reftech is offline
Boat: 1987 mastercraft prostar 190
Snipe all that has to be removed is the transmission. The rear main seal is a one piece seal.run a self tapping screw in the old seal and pull it out then lube the new one one to prevent dry start and tap it in. Done! It was a 3 hour job. Took it to the lake today and have a dry bilge again! Woot!
