I will try to get a look at the bracket on my boat this week and see if it suffers from a similar stress. |
#12
Does anyone know where i might find a bow hook with longer threads? With the added plate in there i don't have enough threads to get the nut started...
You don't have to buy a lake to own it~MasterCraft |
#13
Does the bow eyelet have two nuts that can be loosened from the outside to give you more thread.
#14
http://catalog.hannaysmarine.com/
#15
yes it does, but i would only be able to get about a quarter inch of thread out of it. Not really enough for me..
#16
#17
It should do the trick. I have seen that bow eye and it is long. That is the one I plan to use when I replace mine since I have to work through the access hole I made in the interior of the air intake.
#18
My '83 looks a little different. It is a late '83 with the fiberglass stringers...Is yours? Also, I added a brace to use the lifting ring for the extended pylon strap.
#19
To the best of my knowlegde, the boat is all fiberglass... So you use the lift hook to strap to the high pole?
#20
Yes, with that brace installed. I don't crank the ratchet too much either?
Thread Tools | |
Display Modes | |
