Old 03-24-2013, 02:49 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
Originally Posted by SKI*MC View Post
Yes the high pole strap is looped though the bow hook. The lift ring does nothing but look pretty.
I have a pretty lifting ring as well! Used it to lift the bow up a little so I could replace the front stops on my trailer recently. I think that is the only time I have found a use for it.
I will try to get a look at the bracket on my boat this week and see if it suffers from a similar stress.
Old 03-24-2013, 09:37 PM
SKI*MC's Avatar
SKI*MC SKI*MC is offline
Boat: MasterCraft, Stars and Stripes, 1983, 351 W.
Send a message via AIM to SKI*MC Send a message via MSN to SKI*MC
Does anyone know where i might find a bow hook with longer threads? With the added plate in there i don't have enough threads to get the nut started...
You don't have to buy a lake to own it~MasterCraft
Old 03-24-2013, 09:45 PM
88 PS190 88 PS190 is offline
Does the bow eyelet have two nuts that can be loosened from the outside to give you more thread.
Old 03-24-2013, 09:50 PM
Extended bow eye on right side of page.
http://catalog.hannaysmarine.com/
Old 03-24-2013, 09:52 PM
SKI*MC's Avatar
yes it does, but i would only be able to get about a quarter inch of thread out of it. Not really enough for me..
Old 03-24-2013, 10:56 PM
SKI*MC's Avatar
Thanks for the tip. It looks like one of those might work. I just have to check the measurements on my bow hook.
Old 03-24-2013, 11:14 PM
It should do the trick. I have seen that bow eye and it is long. That is the one I plan to use when I replace mine since I have to work through the access hole I made in the interior of the air intake.
Old 03-25-2013, 02:23 AM
tph's Avatar
tph tph is offline
My '83 looks a little different. It is a late '83 with the fiberglass stringers...Is yours? Also, I added a brace to use the lifting ring for the extended pylon strap.
Old 03-25-2013, 12:56 PM
SKI*MC's Avatar
To the best of my knowlegde, the boat is all fiberglass... So you use the lift hook to strap to the high pole?
Old 03-25-2013, 07:17 PM
tph's Avatar
tph tph is offline
Yes, with that brace installed. I don't crank the ratchet too much either?
