Old 03-18-2013, 09:40 PM
MRomeo430 MRomeo430 is offline
Boat: 1989 MasterCraft Maristar 240 454
Time for a New big block
Last year I bought my first Mastercraft a 89 Maristar 240 with a 454. I bought it running rough and found out my heads were shot ( at least 3 cracked intake runners). Now I'm replacing the whole thing because if it was overheated I won't chance it. I'd like to do a long block set (got a set of old heads from a friend). So a few questions:
1, Mastercraft can't search my HIN it's a year too old, says my HH means 425hp 454 with a 1:1 and a one inch shaft----can anyone confirm this?
2. Anyone have a recommended place to get a long block and parts? (I've been looking at USengines.com
3. Want to rebuild my trans while im in there (had water in the fluid last year) anyone recommend a kit or place to buy one?
Old 03-18-2013, 09:42 PM
Jasper marine engines are as good as they get. They come with a real warranty, but they aren't going to be your cheapest option.
Old 03-18-2013, 10:21 PM
1redTA's Avatar
1redTA 1redTA is offline
you can always check out gm performance parts
https://www.google.com/url?sa=t&sour...RJmCHZfsAvLa4A
1981 MasterCraft
19' Skier 351W PowerSlot
Old 03-18-2013, 10:46 PM
88 PS190 88 PS190 is offline
Trans rebuilds aren't that hard, but there are really only 2 ways that I can think of getting water in there.
A: having enough water in your bilge to get up to the seals/dip stick.
B: A failed trans cooler.
If you never have that much water in the bilge, then the transcooler should be replaced, if you do then stop, and if you do and are seeing transfluid leaks then you need front/rear seals.
If you are doing the engine you can rebuild the trans, but it might not be needed.
Engine wise I don' thave a source, I've never done one, I've looked at several sources however. Jasper I've come across before,
http://www.michiganmotorz.com/marine...s-c-31_51.html
Old 03-20-2013, 10:51 PM
I have looked into Jasper but have not called and I feel the website leaves a lot to be desired. I have checked out GM perfomance as well as every other car site.
The trans is a big concern because I know much about it. I have never seen that much water in it. Im gonna go with a blown cooler. fits just another symptom of my blown overheated motor
Old 03-21-2013, 12:09 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I know a guy that has a newly completely rebuilt LT-1. Cannot give you any specifics on it, but that would be a pretty cool replacement.
Old 03-21-2013, 12:50 AM
Rossterman's Avatar
Boat: 2001 prostar 205V
Not sure i'd want to move to an LT-1 after running that beast of a 454 and huge HP/torque numbers they put out... As they say, "no substitute for cubic inches"
Nothing really special between marinized and non marinized as you can find discussed in several threads.
Old 03-21-2013, 12:00 PM
46Chief 46Chief is offline
Boat: 2002 Prostar 209 "Tarbaby", 2001 Prostar 190 Donor "Holestar"
Summit racing or equivalent online speed shop a new 502 would be pretty fun to drop in.
local speed shop call around you can probably get an built locally.
google around I'd bet you'll find what you need
For trans rebuild, the CC fan board swears by this guy Fantastic Finish Marine
Old 03-21-2013, 10:40 PM
Jerseydave's Avatar
TT Hero
http://high-performance-engines.com/...duct_Code=HP50
ATK makes a 415 hp 454. I've heard good things about their car engines.
I was njskier on here.
