View Poll Results: Do you like this? | |||
yes |
2 | 4.35% |
no |
44 | 95.65% |
Voters: 46. You may not vote on this poll |
Thread Tools | Display Modes |
#12
Aside from looks, not astehtically pleasing to me, having the tow point at the back of the bost would add more "weight" when the line is loaded vs a center tow point, but it would also make the wake change more significantly as the load on the line changed. Not a good thing to have an inconsistent wake, imo.
#13
My initial thoughts.
1: Lever arm from hull to tow point is going to increase for same tow height - regular towers benefit from the fact that the boat, on plane is elevated above water, stern becomes low point. Lever arm increases boarder's pull on boat from higher point. Therefore, the taller tower to get to the same height is going to create more tilt on boat, compared to a shorter tower, forward on the planed hull. 2. Visibility of rider is going to suffer tremendously, with two large blind spots created by tower. 3. While it can be folded, it will HAVE to be folded to ski or use a pylon. Therefore any storage potential, or ability to mount speakers/racks will be negated. Therefore it will have to be "bare" 4. I find the cosmetic poor. It is a heavy looking item in the rear of the boat, the rear is where boats naturally taper off. Consider, the boats have deeper hulls, windows, deeper freeboard etc. midship. By the stern we have cosmetics that naturally taper down to nothing. This design adds components there, making it look back heavy - and in reality this looks like some sort of net laying trawler fishing boat. 5. A mobile mounting point seems both unpredictable and probably dangerous. For one you consider boat stability, for another you consider if it binds and releases, or pops/moves on the cable irregularly. Mechanically you want that to be a fixed point around which the rope pivots fluidly. 6. Finally - I feel like it concetrates too many activities around the platform, consider, you've just dropped a rider, and you turn around to pick them up. They are attempting to board the rear of the boat, while the next rider is trying to also be in the same space to deal with thier board, or manage the line. You have several folks all trying to be around the rear of the boat at the same time. Add in other stern activities, such as hot water showers, or taking a dip, and you concentrate everyone in the stern. In reality folks getting geared up are better served being in the center of the boat, letting the rider climb aboard, and someone tend to the lines easily and with plenty of space. Justifying increased airtime based on the "zipline" and trying to show reduced injury/boat damage loading boards to racks in the rear, also trying to support that the wakes are bigger, the ride better etc... I just don't think you'll get there. Particularly with the other negatives it evokes. You're also going to compromise rigidity since you'll have people trying to move through that space, over the stern, meaning you won't have the area to triangulate the tower that you would if you're over a windshield, where folks already don't walk, and can use the tower for assistance if they did need to. |
#14
If I understand this correctly, you have a cable strung between the two uprights. Without a rigid beam between the two uprights, they'll vibrate like a tuning fork.
I commend you on your idea and asking for input though. I wonder what percentage of people liked the first wakeboard towers designs when they came out. Have you tested this design? Any photos?
'07 Navy Blue X2 MCX http://www.wakeblaster.com/ Ballast Timer Reprogramming Info |
#15
A couple of other points not mentioned yet:
1. You're going to need a lot more structure on the top pole to tie the two side beams together. 2. An important concept in wakeboarding is loading up the rope tension. If you allow the rope to slide sideways with you as you are cutting in, trying to load the rope, the rope moving with you is preventing some of the loading. Also, it's probably only a matter of time before someone adds this one to the ugliest tower award thread. |
#16
Thanks Tr6coug, the patent does have an optional steel support cross bar that cab removed, but I chose to leave out of the drawings. I appreciate the open mind (the first pyolns and towers were hideous). Also- most of the commentary has ben about skiing- so I appreciate that as I dont do that. As for the comments on handling, boats have added tons of shifting weight in the form of ballast to the back of the boat. A little wakeboarder in comparison is not going to make a big impact on modern boats, plus the front ballast can easily offset. I do appreciate every single comment very much though! All of them. Thank you guys so much for taking the time to look and share feedback! At least I know what questions I need to answer out of the box. Thanks again!
#17
The Bimini benefit is also lost over the driver .... Love the fact that you are trying to innovate, keep pushing!
I think someone should invent a rigid telescoping skylon that disappears when not in use ...... ![]()
Keep a tight line, and a smile on your face. Peace out. 2008 Prostar 214 MCX Previous 93 Prostar 190 1.5:1 GT40 "Left Foot Forward and preferring girls." |
#18
#19
kinda like Viagra for MasterCraft? Would you have to rub it to get it to come up?
#20
You could attach a swing to it!
Thread Tools | |
Display Modes | |
