Fun With Trailer, Phase One
Hello my fellow friends,
Today, after much research and apprehension, I decided to remove my Tristar from the trailer for a good ol' rehab project. It was a very interesting experience; mostly a pucker factor.....I have read all types of threads on this procedure; ways to do it etc. I was lucky enough to have access to 2 forklifts, a large shop, and several floor jacks. First I built some cradles out of 2x6 boards and trim board Then, began the slow, painstaking process of jacking up the trailer, moving jacks, and repeat |
And a shot of the trailer..........it needs a lot of love.....a new Spring project
![]() More to follow..... |
Looks like you are off to a great start.
Nice 140 S-Class in the corner there, the last real Mercedes imo
If You Find Too Many Capitals You Can Keep Them...I'm German ![]() It's always 5pm somewhere, time for a beer! |
Thanks, that car is "another" project on my long list...
BTW there is an easier way to do the job.
Your boat comes with a free "boat removal jack" on the trailer. You lower the tongue jack all the way, then you crib up the hull in the rear, since it is behind the axle, when you run the jack up again the rear will land on the cribbing, and as you crank it will eventully lift off the bunks in the rear and up off the trailer. Although with two nice fork lifts I'd be thinking a spreader bar and webbing. |
insurance
After a lot of reasearch, and all the tools I had access to (forklifts, shop, etc) I went with this idea. The stern lifting hooks proved to be a strong lifting point, as designed. I didn't trust the bow lift eye, it just didn't seem strong enough, so I just used a series of jack stands and a floor jack to position, and reposition, and again. Below, pics of how it stands now....."insurance" with lots of back ups. Jack stands on the bow, and floor jack on the bow, large foam filled sponsons to support the stern, and a cable ran through the stern lifting hooks, connected to an engine hoist. Then, to further give me piece of mind, 2 boat stands on either side of the transom. Only an act of God could knock this thing over.......hmmmmm, I do live in the Northwest...more to come.
Phase 2
Today, I took everything off the trailer (wench, wheels, bunks, bow roller, center pad, and the guide rails. The only thing I didn't get off yet wer the lights, and the center keel roller. It has the caps on the outside of the bracket that holds the pin. They, as most of you know, are a "hat" shape. How are they removed? Looks like they are pressed on. I tried prying with a screw driver, but I didn't want to break it or bend it up. It did give a fight as is while I pulled on them. So, any suggestions on how to remove the end caps holding the roller on? Thanks.
http://www.lowes.com/pd_65291-37672-...nut&facetInfo= Looking good with the project.
'96 ProStar 205 SD LT-1 |
Thanks, that was easy.
Thread Tools | |
Display Modes | |
