  #61
Old 03-09-2013, 09:31 PM
Originally Posted by SWGA Boater View Post
Pulled a four hour grinding session this afternoon. Have I mentioned how I hate grinding? Have the transom ground smooth except in the lower corners where it is reallly tight. I plan on using a little barrel disc tomorrow afternoon to finish the transom up. Grinding is slow on the driver's side. I found several places with some rotten glass and blisters. These areas look to be over the bunk. I checked the bottom of the hull and cannot find any blisters. Not sure under the bunks. I hope the rotten glass and blisters are related to the previous floor replacement. Had to grind down to the gel in several small places. Will have to patch these prior to the stringers going in. I'll post some pictures when i get the boat vacuumed and washed out. US Composites order came in on Thursday, so i have to get myself in gear and get back on the boat.
I think I am going to try and replace the transom in one piece. I bought a ski eye that I plan to add to the transom. I am hoping to cut the transom to size, and then put some weight on it to start the bend. I then will use the ski eye holes and swim deck holes to pull the transom tight. That is the plan unless somebody else chimes in with suggestions.
Can't decide on glueing the transom in with PL glue or us thickened resin. Any thoughts?
I have been wondering how you are going to get this back together. I will continue to follow.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 03-09-2013, 09:40 PM
SWGA Boater's Avatar
Boat: 1991 Prostar 190
I hope it works....3/4" ply doesn't like to bend....
Old 03-09-2013, 10:26 PM
Not much. Have you considered building a jig?
- Peter
TIRE & WHEEL SALES
WHEEL SPECIAL
