It's a 2011. Sent that info in with my email to MC.
#12
Talked to wakemakers today. They said the rear tanks are 250# and kgb 400# for sure. They said on 2003 and older they were 150# and 250# respectively. Said they keep info on all the makes and models and the guy I talked to told me he has a Mastercraft also.
#14
The rear sacs are plumbed in, and with the 6 min timers will fill the sac maybe 80%. If I need the sacs full I will manually fill, I set up the fittings to do this easily. The bow sac is not plumbed in and manually filled using Tsunami pump. For me this system works easily enough and not too much pain, couldn't justify $100 a timer either |
#15
How many lbs are the '12 tanks? Can you install the three way valve fly high kit (without factory PnP) in the '12's? I heard the bow sac is two bricks now...
#16
I believe stock tanks for '12 are also 900 pounds. The timers went away for 2012, and originally, you had no way to run the factory pumps longer. The latest software update is supposed to allow your dealer to calibrate your pumps to run longer if you have extra bags. I haven't gotten the software yet. I got one of the first 2012 models. I ordered the fly high kit and quickly discovered that the the one bow sac no longer worked. Wakemakers was unaware of the change. I had the V drive sacs that I used to use in my 02 X Star, so I plumbed them up front. I just T'ed them together. Here's some pictures and hose lengths of what I did.
#17
Also, I've never weighed what I can get with the two sacs up front, but it's not a huge amount. I also throw a bow triangle sac up front if I don't have a lot of people in the boat.
#18
Are that sacks up front fill completly?
#19
My front sacs do not fill completely. The back portion does, but up under the seat, the hull cuts off a lot of volume. I also don't know how the V drive sacs I used compare to what the new fly high kit includes. I haven't seen the new separate front bags that are mentioned above.
#20
I see you have a wrap in your picture of your X2. Got a better picture? |
