#81
Got more done today. Installed the starter, oil pressure sensor, and cleaned up the drive shaft seal. I also painted the pick up loops for the engine and will bolt them on this weekend. The fuel/water separator cap was also painted.
![]() A package came today from skidim.com, it has 2 transmission hoses, a raw water pump impellar, and thermostat. I ordered a new drive shaft with coupler, it should be coming in towards the mid to end of next week. Also, I got my second-hand alternator tested. It checks out, so I dont have to spend $150-$200 bucks on a new marine alternator as of now. Working hard to get this thing together asap! |
#82
Check out what came in!
![]() I have to get some carpeting done and I can work on getting the beast into the boat. I found a steel fab shop not far from the house that has a fork lift. They agreed to help me get my motor into the boat. I was hoping for this week, but that doesnt look like it will happen. Maybe next. I started tearing into the carb. It def needed it. Im still not sure if Ill end up replacing with a new one or not. For now Ill try to rebuild this 4160. Its a learning opportunity. ![]() ![]() I got another coat of paint down on the bilge too. |
#83
If you need any assistance on the rebuild, I will be more than happy to assist. The most important part is to soak it long enough.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#84
As I get going, Ill be asking other questions along the way. |
#85
You might give Holley Tech a call. The stock screws should be cheaper. 270-781-9741
#86
I'll let you practice on your carb. When your up to it I'll send mine your way!
#87
In general it doesnt seem to be that big a deal really. Just dont take the screws out of the valves in the baseplate! I could give it a go if you want, but by no means am I willing to give you a guarantee of proper function afterwards. Lets find out how mine ends up working and I may change my mind. |
#88
I got the carb almost completely back together. I have to get another choke cap and then that part can be reassembled. I finished applying a coat of bilge paint to the rest of the floor in the boat. It looks nice, kinda a shame I have to cover it with carpet. I also installed the shaft seal, its not a big deal, I just mostly wanted to see what it looked like. I havent ordered carpet yet, looking for a good deal I guess.
here are some updated pics. Carb with a few missing things: ![]() Carb underside: ![]() Shaft seal: ![]() Painted Floor: ![]() The choke and vacuum pump for the secondary are what is left to attach on the carb. I might order carpet tonight. |
#89
Maybe it's just the angle, but the accelerator pump arm doesn't appear to be square with the bolt it mates with. Might want to double check all is right here.
#90
Maybe you could enlighten me? On of the other things Ive noticed is that the butterfly valves, the primary ones move very freely until I want to close them, then they seem to bind up a little somewhere. Im pretty sure that is an issue that needs to be addressed. |
