Impact Vest
I have been looking at a Ronix Impact Vest for this year’s wakeboarding season, and wondered if anyone had any experience with this type of vest. I currently have an HO, neoprene vest that fits pretty tight, but these impact vests seem to provide a bit more protection against a hard fall.
Had anyone used a similar style vest, and was there any real benefit. |
only experience i have with an 'impact vest' is an older jetpilot my buddy used to like to ride. Another friend put it on to swim to a jumping bridge on a lake trip. realizing it wasnt floating him much, turned to me and said, "hey will, if i was ever knocked out and fell out of my board this is how fast you'd need to turn the boat around to get me" he put his arms up, stopped kicking and sank like a rock.
IMO i wouldnt wear one unless i knew it floated me |
I'd rather take an impact to the ribs than a drowning any day, makes for a better story ![]() |
I typically use a JetPilot O'Shea comp vest for surfing and a Billabong USCG approved neo vest for wakeboarding. As others have stated, the Billabong is used to float me at the right level in the event I suffer an injury that renders my lifeless.
2012 X-30 - Fort Loudoun Lake, Knoxville, TN |
if your really looking for flotation you might want to consider a barefoot suit. i use a 3/4 length barefoot suit and it has plenty of protection and flotation. if your worried about it resisting your movement i wouldn't be, i do everything in my suit from slalom skiing, wake skiing, and jumping.
At one point years ago I wore a Jet Pilot A-10 comp vest. It really doesn't provide much float and I felt it wasn't safe. I switched to a Revenge. Last edited by Eagle; 03-19-2013 at 12:29 AM. |
I have not been in an impact vest that felt like it would actually float me so what is the point?
Many Comp vests do have enough flotation to keep you up but dont meet the even higher flotation of CG certifications. Single strap of a comp vest is nice but I did not find the dual strap significantly affected movement. A three strap encumbers enough to notice IMO. I really like the JetPilot side entry vests. The solid chest takes a hit and protects much better than a front zip. The Cellblock style with segmented sections allows movement almost as good as the a-10 but with more flotation. I have another super thick one that I usually only use in the shoulder season mainly because it is thicker and warmer. I dont care for the Baller series, the foam is thinner so it does move but it is still a single piece so it does not bend as comfortable as the segmented vests. |
