Old 02-25-2013, 04:22 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Extended storage? X2
Well, may be heading to Alaska for the next 2 years. Not taking the boat for obvious reasons. I can layup the boat in my shop where it sits in the winter for about 8 months anyway, so it dry and protected, but a couple years is a different story.
Couple things I'm planning in addition to everything required to winterize normally (already done) are as follows:
Block up trailer on frame to keep the weight off the axles and tires (never done this before, but usually end up moving the boat once or twice in the offseason for some reason).
Fog the cylinders. (Again, never done in the past for a winter layup, but probably will do for 2 year layup.)
Pull the batteries. (And put them in my truck. OE batteries are 7yrs old in the truck anyway and hate to trash a couple high dollar Odyssey batteries and dont want them sitting that long unattended on the maintainer.)
Fuel? This is the big question. Typically I just run it low, Seafoam it and call it good for the winter, never had any trouble with that. But 2 years, closer to 3 yrs maybe adding in this current off season, is different. I'm sure the fuel pump "should" stay wet, but what ever, that's an easy cheap replacement if when it craps out. Drain the tank? How to get all the fuel out?
What about the engine/fuel rail? Run it out of gas? What's best with regards to this?
If I was close to someone I trusted I'd rather it get run a few times each summer, but not possible here.
Any other suggestions?
'06 X2 MCX
Old 02-25-2013, 05:35 PM
Dylan's Avatar
Dylan Dylan is online now
Boat: 15' VALCO
It sounds like you have a handle on the situation. It's a shame you're not taking the boat, I heard crab fishing up there off an X2 is the norm
Old 02-25-2013, 05:39 PM
Rockman's Avatar
Rockman Rockman is offline
If you put blocks under the trailer to get the weight off the tires, won't that cause the axles to bend over time?
That's what my uncle told me...he used to have a number of classic cars and never put them up on blocks for this reason. He just made sure he rolled them back and forth every so often.
Our BF200 has been stored up north for 2+ years now with a bad motor and we have not moved it since we put it in the garage...everything seems fine...
Old 02-25-2013, 05:49 PM
Maybe you can Lumbergh or someone run it a few hours a year to keep all the seals and other important internals lubricated correctly....I know I could count on someone near me to take good care of my PS205 a few times a season if I was in your situation...
Old 02-25-2013, 06:14 PM
sand2snow22's Avatar
Boat: Ri257
I will take good care of it
Old 02-25-2013, 06:22 PM
bjen bjen is offline
Boat: looking-2003 X2-sold-
If he blocks the frame like he says, nothing to worry about-have to get the tires up.
Too bad you dont have someone you trust to run it, that would be best but a pain to put back to bed again after an hour or 2. I used a simple hand transfer pump with an extended hose to drain my tank, kind of rolled one side of the trailer up on a block to get it all to one end.
Have you considered putting it up for sale, 2-3 years is a long time, big chunk of the depreciation is gone already I guess but you may get into something newer for the same money in a few years. It never ceases to amaze me the low hour, quality boats that come up for sale.
Old 02-25-2013, 06:25 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Too bad I bought a Blazer last summer-now I don't have room in the garage at my lake place. It could've stayed in my garage at Priest next to it's paternal twin and Sands could use it when he makes it up during the summer.
2006 Maristar 200 SS
Old 02-25-2013, 07:53 PM
Thrall's Avatar
Boat: '06 X2 MCX
If I lived back in IL again where you are I'd have no problem getting the boat "excercised" by good friends who are also MC/boat owners, with confidence. Got one in Naperville and 1 in Fox Lake that would keep 'er up.
Only 1 friend out here I'd trust to do that and he's getting sent to Victoria BC for a project for the next 2 years and doesn't plan on coming back here at all.
'06 X2 MCX
Old 02-25-2013, 07:59 PM
Thrall's Avatar
Boat: '06 X2 MCX
Yeah I figured block the frame like you said. Then again I have yet to ever block anything up for storage with no ill effects.
Have thought about selling it. With only 150hrs and in cherry shape (orig owner never used it and I only seem to get 30-40hrs/yr) I could still sell it for more than I paid for it, but that's a tough one. Not in a position that I need to sell it and I put a fair amount of work into it already. Plus I searched a while for pretty much this exact boat, with some of the big things being no exhaust cats, no digital guages, 06 tower, black.
Don't figure I'll "lose" much by letting it sit either. Wakeboats aren't getting any cheaper!
Not sure what I was thinking on the fuel. If I pop the filler hose off the tank, should be able to suck out 95% from there without much trouble. Thanks for the suggestion there.
'06 X2 MCX
Old 02-25-2013, 08:06 PM
Thrall's Avatar
Boat: '06 X2 MCX
Put your Blazer in my shop (better yet I'll keep 'er lubed up in AK for you!) and I'll leave the boat over there!
That might not be a bad idea. Then if we make it back down here during the summer it'll be ready to go.
He!! I still owe you for a cushion anyways.
I'm sure you guys would take care of it.
Eh I dunno, isnt it a little incestuous to let 2 MC's share the same room?
'06 X2 MCX
