How big a garage for an X-star?
Hey Guys,
starting to look at houses/condos. i would really like the option of keeping my 2007 xstar at the house if a bad storm or a cold night is coming. i have really cheap winter storage, so that wouldn't be a huge deal. Does anyone here keep their star in the garage? i know my trailer is 24 ft even with the fold-away tongue, and since its a 2007 i have the exhaust tips that stick out about 4 inches. How big does it need to be to fit? |
sounds like 24'-4" . If you don't mind angling it in alil bit you can cut that down. I have a 2005 star trailer and fit my boat in a 20'x20' garage but its a 20 min ordeal to get in, get platform off, etc since you have to hand angle it on double layered plastic. If you were just doing it in a pinch you can make alot work. In my area its almost impossible to find 24'+ garages unless you build it yourself.
Even if you can find a really deep garage I've found that the depth isn't the real problem on my 07 X2 but the height of the door. Even with my tower down I had issues getting past the windshield and the racks. I ended up having to lower the dolly wheel all the way down to get past the windshield then taking the entire back half of the tower off to get clearance for the racks. I'd expect that with the Star the boat would be even taller and most garages will not have a door that is going to give you the vertical clearance to get it in the garage.
garage size
Our garage is 21'6" long. Our old boat (96 PS 190) was 21'4" long on the trailer w/o platform. From my experience with this, it was a nightmare. It was extremely difficult to get the boat into place and I had ductape on the floor to mark where each wheel had to be. I typically had to move it the last 3-5 feet by hand. This was difficult with a 2400 lb prostar on a 1000 lb trailer. If you have to do this with a 4000 lb star on a 1000 lb trailer I would say it will be extremely difficult. You probably have a tandem trailer too which will make turning next to impossible. My suggestion would be not to cut it close. Make sure you have sufficient room to move the boat with your tow rig and not by hand.
If you get lucky enough to find the right size garage, great. Otherwise don't base your house purchase on the garage, you can always build one.
I'm lucky......40X52 pole barn with 12X12 ft doors. My tower has never been down since new. We had this built for under $24K. No concrete floor yet however. ![]()
I was njskier on here. |
very nice!!!
"Hey baby want to make fourteen dollars the hard way?"--Rondhey Dangerfeild-Caddy Shack. "Was it over when the German's bombed pearl harbor ?" ---Animal house |
