  #81
Old 02-18-2013, 11:45 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Look into using the pre-fabbed plastic brake line. You can build a kit for approximately the same price and they will never corrode and are quieter in the box frame than the metal brake line.
http://www.pacifictrailers.com/THERM...rake-Line-228/
Old 02-18-2013, 12:06 PM
MCOCD@13 out of 10
I added this 2 years ago.... works great.
Old 02-18-2013, 12:16 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Those look pretty interesting. I never did like all the rattling on the outside of the tubing. Can I get those into the axle tubes to cross over to the other axle calipers or do they still need to be on the outside? The main line I pulled out was surrounded by some type of foam covering. Probably kept things more quite but also trapped in moisture longer.....so the plastic line seems like a good option.
Either of you two have any pics of your install?
- Jeff
1994 205, LT1
Old 02-18-2013, 12:23 PM
Sodar's Avatar
I still ran hard lines outside the axle tubes to the outboard calibers. I never thought of running them inside, but I guess it would be doable.
Old 02-18-2013, 12:28 PM
MCOCD@13 out of 10
I did not change those...they did not rust out. It was the internal one from actuator to coupler that I changed. From coupler to drums (in my case) line was still good.
I have the parts in the kit I bought waiting to be installed.
Old 02-18-2013, 12:49 PM
Ski-me's Avatar
Don't we all.... I bought those brakes in November and finally found a nice weekend to install (58 on Saturday). Woke up this morning to an inch of snow.....
I'll have to look at it more closely to see if a route inside tube is doable. If not, I'll stick with the outside at least for the axle crossings.
- Jeff
1994 205, LT1
Old 02-18-2013, 03:05 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Should sticky this, great detailed writeup on doing wheel bearings and brakes.
Old 02-18-2013, 03:32 PM
Table Rocker's Avatar
Yes, this is a great thread with tons of good pics. Job well done!
'96 ProStar 205 SD LT-1
Old 02-18-2013, 05:57 PM
MCOCD@13 out of 10
stickied...
Old 03-05-2013, 10:22 AM
Ski-me's Avatar
OK, I've looked into new lines and it seems to be a slippery slope. I'm good with the mainline being the Thermo-Plastic....that's a pretty easy decision. However, I need only about 12-13' instead of the 19'. Is the Thermo Plastic bendable enough to double up inside the frame rail?? I don't want to pinch it.
What I thought would be easy was to just use Stainless Steel for the rest of the system. What I've found is that the SS is harder/more brittle than the standard coated steel and the flaring is different. If I went SS, I would most likely get a spool of it and then cut/flare as needed.
The standard tubing flares at 45 degrees and actually double backs onto itself for the lip.
Whereas the SS tubing is at 37 degrees and an extra backing sleeve needs to be added as part of the connection. On top of that, the two can't be intermixed as they won't seal properly.
Finally, I can't use the nice, CHEAP tube benders and flaring tools from the local auto parts store for the SS tubing. I'll need the nicer equipment to do a proper flare.
With all that said, it looks like my only option is the Thermo Plastic main and then the coated steel. Unless I'm missing something.
- Jeff
1994 205, LT1
