96 190 Fuel Tank Removal
In the process of restoring 96 190, I want to remove the fuel tank to clean the tank, replace fuel sending unit, and clean behind the tank. I understand the fuel system is high pressure. Should this cause me any concerns. Do I need to be aware of anything before the removal and install? Thanks.
Getting the tank out isn't too bad. Remove the two hoses at the top of the tank along with the wires to the fuel sending unit. I tied mine up high so they wouldn't leak out all the gas. It wouldn't be a bad idea to note which sending unit post the red wire is on, although I think it works either way. Take the screws out of the clamps that hold the tank to the floor. On my boat, I also took out the black plastic panels that separate the side ski storage from the tank area (2 screws each). The hardest thing to remove for me was the filler hose. I loosened the clamp and then slid the tank forward to give myself a little room. Then just slide the tank out, one end first. I had to repair my sending unit, so when I had it out I took the tank sump out and cleaned the tank out. I had plastic shavings from when the tank was first put together and a dead field cricket to clean out, but other than that it was clean.
'96 ProStar 205 SD LT-1 |
Table Rocker, your the man. Now that's service, an answer in less than 30 min. Thank you! |
Check the inlet on the pump as well..there is a small screen that clogs easily....
Also, have you checked the engine water pump.. being a '96 I bet that pump is ready to fail any day now. I replaced my '97 last spring and the pump was shot...rusted inside...etc. |
Filler hose replacement experience:
Order a new piece of hose and cut the current hose to separate from fuel cell and filler neck. Saves a ton of headache and scratches (or in my experiences). That hose is hardened and is difficult to remove, thus I succumb to a quick cut and replacement. $0.02 .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
| Tags |
| 190, fuel, prostar, tank |
