Old 02-14-2013, 12:16 PM
Juiced190's Avatar
Juiced190 Juiced190 is offline
Boat: MasterCraft, Prostar 190, 1996, 350
96 190 Fuel Tank Removal
In the process of restoring 96 190, I want to remove the fuel tank to clean the tank, replace fuel sending unit, and clean behind the tank. I understand the fuel system is high pressure. Should this cause me any concerns. Do I need to be aware of anything before the removal and install? Thanks.
Old 02-14-2013, 01:28 PM
Table Rocker's Avatar
The high pressure is between the fuel pump (back of the engine) and the injectors, so no problems there.
Getting the tank out isn't too bad. Remove the two hoses at the top of the tank along with the wires to the fuel sending unit. I tied mine up high so they wouldn't leak out all the gas. It wouldn't be a bad idea to note which sending unit post the red wire is on, although I think it works either way. Take the screws out of the clamps that hold the tank to the floor. On my boat, I also took out the black plastic panels that separate the side ski storage from the tank area (2 screws each). The hardest thing to remove for me was the filler hose. I loosened the clamp and then slid the tank forward to give myself a little room. Then just slide the tank out, one end first.
I had to repair my sending unit, so when I had it out I took the tank sump out and cleaned the tank out. I had plastic shavings from when the tank was first put together and a dead field cricket to clean out, but other than that it was clean.
'96 ProStar 205 SD LT-1
Old 02-14-2013, 01:37 PM
Juiced190's Avatar
Table Rocker, your the man. Now that's service, an answer in less than 30 min. Thank you!
Old 02-14-2013, 01:58 PM
My pleasure, good luck with it. If you don't already have an inline filter on top of the tank, now is a good time to put one there. A WIX 33003 and two hose clamps does the trick.
Old 02-14-2013, 03:16 PM
flya750 flya750 is offline
Boat: PS190
Check the inlet on the pump as well..there is a small screen that clogs easily....
Also, have you checked the engine water pump.. being a '96 I bet that pump is ready to fail any day now. I replaced my '97 last spring and the pump was shot...rusted inside...etc.
Old 02-14-2013, 07:44 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Filler hose replacement experience:
Order a new piece of hose and cut the current hose to separate from fuel cell and filler neck. Saves a ton of headache and scratches (or in my experiences). That hose is hardened and is difficult to remove, thus I succumb to a quick cut and replacement.
$0.02
Old 02-15-2013, 10:22 AM
MC Platinum
$0.02
Great advice. Been down that road before.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 02-15-2013, 10:29 AM
Juiced190's Avatar
$0.02
Thanks for the advice Cloaked, anything that saves time and blood you can count me in on. 👍
190, fuel, prostar, tank
