#121
'96 ProStar 205 SD LT-1 |
#122
My experience has been to leave the green disconnected. Done deal for me. Fuel sender works and no ground to a fuel filler neck. Kinda' like the battery sitting within the same enclosed area as the fuel cell (on my 93). Something about that made me uneasy. I moved my battery to the front under the observer seat. .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . |
#123
Fuel tank cleaning
Been trying to get rid of the tide line on the exterior fuel tank ,I cannot bring myself to put back looking the way it does.
Tried truck wash , petrol ,toilet bowl cleaner ,wheel acid all been left to soak and scrubbed but nothing seams to move it . Any ideas on this Wet sanded the transom 800 ,1200 then compounded, comes up okay but I can still some light scratches so will need a another pass. Got rid of all the dirt in the hull , need to compound all the inner gell areas which have been stained by the steel staples used on the trim panels . Still waiting on the engine block to come back from the shop. |
#124
Try mixing up a "hefty" solution of Iron Out in a large enough container. Set the tank in and weight it down. Let soak for a couple of hours and rinse it off real good. It does need to soak though; just wetting it won't do much. That does wonders on rusty surfaces, it may just work on this.
Good luck. The project looks like it's moving right along, very impressive. Last edited by Snipe; 04-08-2013 at 07:23 AM. |
#125
I wonder if oxyclean would clean the tank or maybe chlorine. Just guessing here
#126
Injectors arrived
2 new injector kits arrived today ,
I ended up buying these from Accuratediesel in Bitely,Michigan , Tim who works there was spot on all the way , plus a great price . |
#127
Great!! Do these have to be Marine specific?? If I may ask, how much were they?
#128
Hi No not Marine specific, MikeG got me the oe injector part number which crossed to the Delphi part . Kit includes complete seal/gasket set as well. cost $110.00 for the pair shipped to the Uk |
#129
wow... that boat is looking great compared to the beginning post... nice job!!
Amazing what wet sanding and compounding will do!
