  #121
Old 02-06-2013, 06:51 PM
Table Rocker's Avatar
Originally Posted by Worthing skier View Post
Hello all
Hopefully an easy question this time ,
On the rear wiring loom for the fuel tank sender unit the is a plug/socket with 3 wires
black , pink and green ,
Black and pink are for the tank sender , I am not sure re the green wire , possibly a ground wire for the fuel filler neck but not sure .
Any advice on this.
thanks
Kevin
I have a green ground going to the back of the filler neck.
'96 ProStar 205 SD LT-1
Old 02-06-2013, 07:57 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Hello all
Any advice on this.
thanks
Kevin
There is a legacy thread here somewhere on the ground wire. Something to this effect: MC said don't ground there, even though we did. Run a ground to another part of the boat and not on the filler neck.
My experience has been to leave the green disconnected. Done deal for me. Fuel sender works and no ground to a fuel filler neck.
Kinda' like the battery sitting within the same enclosed area as the fuel cell (on my 93). Something about that made me uneasy. I moved my battery to the front under the observer seat.
Old 02-10-2013, 08:57 AM
Worthing skier's Avatar
Worthing skier Worthing skier is offline
Boat: mastercraft prostar 190 1993
Fuel tank cleaning
Been trying to get rid of the tide line on the exterior fuel tank ,I cannot bring myself to put back looking the way it does.
Tried truck wash , petrol ,toilet bowl cleaner ,wheel acid all been left to soak and scrubbed but nothing seams to move it .
Any ideas on this
Wet sanded the transom 800 ,1200 then compounded, comes up okay but I can still some light scratches so will need a another pass.
Got rid of all the dirt in the hull , need to compound all the inner gell areas which have been stained by the steel staples used on the trim panels .
Still waiting on the engine block to come back from the shop.
Old 02-10-2013, 09:46 AM
Snipe's Avatar
Snipe Snipe is offline
Boat: Mastercraft ProStar 190 Vortec MX Plus E.F.I.
Try mixing up a "hefty" solution of Iron Out in a large enough container. Set the tank in and weight it down. Let soak for a couple of hours and rinse it off real good. It does need to soak though; just wetting it won't do much. That does wonders on rusty surfaces, it may just work on this.
Good luck. The project looks like it's moving right along, very impressive.
Old 02-10-2013, 05:02 PM
saltybalty saltybalty is offline
Boat: 1996 205 Prostar LT1
I wonder if oxyclean would clean the tank or maybe chlorine. Just guessing here
Old 02-11-2013, 04:35 PM
Injectors arrived
2 new injector kits arrived today ,
I ended up buying these from Accuratediesel in Bitely,Michigan ,
Tim who works there was spot on all the way , plus a great price .
Old 02-11-2013, 04:59 PM
Snipe's Avatar
Great!! Do these have to be Marine specific?? If I may ask, how much were they?
Old 02-11-2013, 05:29 PM
Hi
No not Marine specific, MikeG got me the oe injector part number which crossed to the Delphi part .
Kit includes complete seal/gasket set as well.
cost $110.00 for the pair shipped to the Uk
Old 02-12-2013, 08:36 AM
MCOCD@13 out of 10
wow... that boat is looking great compared to the beginning post... nice job!!
Old 02-12-2013, 08:43 AM
carisch carisch is offline
Boat: 225 vrs 1996
Amazing what wet sanding and compounding will do!
