Old 02-09-2013, 08:02 PM
LotusV8 LotusV8 is offline
Boat: 1989 Mastercraft Prostar 190
1989 Prostar Ski Pylon/Pole Removal
I'm replacing my carpet and need help on removing the ski pole in order to remove center wood plank.
I have loosened the U clamps but do not know what to do next.
I see many of you guys remove them to have powder coated , so I know I'm just missing something.
I did do many archive searches and cannot find removal details.
Thanks for any help you can offer.
Old 02-09-2013, 08:06 PM
Cloaked Cloaked is offline
Boat: MasterCraft
All of the boats I have had, that center section will lift right up over the pylon. No need to remove.
Old 02-09-2013, 09:53 PM
tph's Avatar
tph tph is offline
That panel may go under the observer base (which is part of the deck assembly on a '89) So, you may have to remove the pylon. I think it's only secured with the two "U" clamps. Is it corroded?
Old 02-09-2013, 10:50 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Originally Posted by tph View Post
Is it corroded?
I was about to suggest the same thing. Should just pull up. Try twisting slightly or tapping gently with a rubber hammer.
Old 02-14-2013, 07:39 PM
89BigBlock's Avatar
89BigBlock 89BigBlock is offline
Boat: 89 prostar 190 454
That floor piece goes under the observer seat like mentioned above and IS connected by two U clamps in opposit directions. One goes through the hull that is shaped also like a U, and the other goes through the AL support under the floor.
Old 03-03-2013, 12:13 PM
Ski pole is out and center board removed.
Thanks for all the help!
LotusV8
