Old 02-09-2013, 09:02 PM
LotusV8's Avatar
LotusV8 LotusV8 is offline
Boat: 1997 Maristar 225 VRS
1989 Prostar Ski Pylon/Pole Removal
I'm replacing my carpet and need help on removing the ski pole in order to remove center wood plank.
I have loosened the U clamps but do not know what to do next.
I see many of you guys remove them to have powder coated , so I know I'm just missing something.
I did do many archive searches and cannot find removal details.
Thanks for any help you can offer.
Old 02-09-2013, 09:06 PM
waterlogged882 waterlogged882 is online now
John 3:16-18
Old 02-09-2013, 10:53 PM
tph's Avatar
tph tph is offline
All of the boats I have had, that center section will lift right up over the pylon. No need to remove.
That panel may go under the observer base (which is part of the deck assembly on a '89) So, you may have to remove the pylon. I think it's only secured with the two "U" clamps. Is it corroded?
Old 02-09-2013, 11:50 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Originally Posted by tph View Post
Is it corroded?
I was about to suggest the same thing. Should just pull up. Try twisting slightly or tapping gently with a rubber hammer.
Old 02-14-2013, 08:39 PM
89BigBlock's Avatar
89BigBlock 89BigBlock is offline
Boat: 89 prostar 190 454
That floor piece goes under the observer seat like mentioned above and IS connected by two U clamps in opposit directions. One goes through the hull that is shaped also like a U, and the other goes through the AL support under the floor.
Old 03-03-2013, 01:13 PM
LotusV8's Avatar
Ski pole is out and center board removed.
Thanks for all the help!
LotusV8
Old 08-10-2013, 07:30 AM
mpdobson mpdobson is offline
Boat: Prostar 190
Did you remove the centre board by taking it out towards the bow of the boat? I am in the process of replacing my carpet but i am having some trouble getting this piece out.
Sent from my iPad using Tapatalk HD
