Old 02-06-2013, 07:28 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 1994 Prostar 205
Sea Foam Engine Cleaning
I would like to see if I could clean the internals of my LT-1 as far as removing carbon deposits using Sea Foam. Currently I just add it, or something similar, to the fuel tank. I have looked at several videos on how it is done on a car, but didn't really see any with a boat. I would assume it would be the same procedure by sucking it in through a vacuum tube but I do not know which tube that would be. Has anyone done this before on their boat? I do not want to add it to the oil until the end of the season when it is time for an oil change again.
Old 02-06-2013, 07:42 PM
MCOCD@13 out of 10
I don't see why you could not do the same as in the youtube videos. How do you know you have carbon deposits? If you do it - please make videos.
j.mccreight@hotmail.com j.mccreight@hotmail.com is online now
I haven't used seafoam as top end cleaner although I have used gm's top end cleaner, simply use a manifold vacuum source (like your pcv port) you will need to keep the revs up until all fluid has been consumed and it will very likely smoke. I haven't done a boat but have done many cars.
James
Old 02-06-2013, 08:53 PM
Indmar bulletin, It appears this method just cleans the rings and top of pistons and not valves.
Indmar Products
5400 Old Millington Road
Millington, TN 38053
Phone 901-353-9930
Fax 901-358-4292
Procedure for applying Upper Engine Cleaner Kit S495149
1. Drain the oil from the engine. Not the filter.
2. Leave the cap off the oil drain hose.
3. Remove the fuel rail and fuel injectors.
4. Add 2oz of the UEC to each cylinder through the injector holes.
5. Mark the balancer as a reference.
6. Turn the crank 720°. This will push the cleaner into the piston ring lands.
7. Let the chemical set for 1.5 hours.
8. Add 2oz of UEC to each cylinder for a second time.
9. Turn the engine over 720°. Note: You should be close to or hydro lock on
each cylinder.
10. Let sit another hour.
11. Spin engine over by hand until free.
12. Add 1 quart oil and let it drain out.
13. Install the cap back onto the drain hose.
14. Fill engine with oil.
15. Reinstall the fuel injectors and fuel rail.
16. Put the boat in the water and start the engine. Let it idle until it reaches
operating temp.
17. Drive the boat keeping the RPM above 3500 for 10 minutes.
18. Perform many WOT launches.
19. Change oil and filter.
Flat Rate Labor Allowance: 2.5 Hr (Add .5 if plenum must be removed to access
fuel rail.)
James
Old 02-06-2013, 09:18 PM
CC2MC's Avatar
Hmmm. Interesting. Thanks for the info j. It does not appear to be as straight forward as a car, unfortunately and it says the chemical has to sit for a couple hours, where a car is only about 10-15 mins.
@mikeg205, I noticed that my throttle body has a decent amount of deposit behind the butterfly valve and I figure with a nearly 20 yr old engine, there has to be some inside the as well. I am not having performance issues or anything, just thought it couldn't hurt. If I do end up doing it, I will be sure to video and/or take good pics.
Old 02-06-2013, 09:56 PM
kalamalka kalamalka is offline
Boat: mastercraft x1 2006
Glad I read that first, thanks.
Old 02-06-2013, 10:05 PM
1redTA's Avatar
1redTA 1redTA is offline
1981 MasterCraft
Long gone is the Trans AM
Old 02-06-2013, 10:23 PM
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 02-06-2013, 10:26 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
I'm running a tank of fuel with Seafoam in my '04 Xterra with full throttle accelerations and 80mph runs on the tollway by my home (did wonders for it). Runs smooth as silk again. Same should hold true for your MC.
I run Seafoam through my 200 Mercury Outboard with solid results as well.
Old 02-07-2013, 12:46 AM
psychobilly's Avatar
They need to be careful on Step 14: Fill Engine With Oil
I had some buddies in High School that their family owned a garage. Someoene came by asking how to change the oil in their car, told them simular steps and one was, "Fill Engine with oil". Guy came back and said engine wouldn't start... When he explained he "Filled it until it was full" with the case of oil he had bought, not sure actul it took but he said it was full and he couldn't get anymore in it......
Gotta watch how we say things I reckon LMAO
