  #211
Old 09-10-2011, 09:58 AM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Old 09-14-2011, 02:21 AM
Scottman's Avatar
Scottman Scottman is offline
Boat: 78 S & S
After a lot of research I couldn't be happier with my Blue Sea "Add A Battery" System.
Thanks to reading this thread for the suggestion...haven't had a single battery related problem since I installed it this spring.
I have one cranking battery and one deep cycle. I just turn the switch to ON when I start and OFF when I put her away at night. Then there's COMBINE if I ever needed it.
Easy installation too...any questions about it just let me know.
Old 01-09-2012, 09:10 PM
Scottman's Avatar
Boat: 78 S & S
Also wanted to say that I got a great deal on my cables at http://genuinedealz.com/
I ordered everything and had them make the cables for me. They all arrived exactly as I ordered, and I just had to hook them up. Great prices, and they made them just how I wanted them. Really couldn't be happier. I first heard of them through a post on this site, so thanks to whoever posted the link (I think it was sodar)
Old 01-21-2012, 08:33 PM
Lumbergh's Avatar
What gauge are the factory battery cables on a Prostar?
Old 01-21-2012, 09:06 PM
Boat: wooden, boat, 1908, putt
Four for most. Stands true for the 93 for certain.
Old 05-28-2012, 08:53 AM
Philscbx's Avatar
Philscbx Philscbx is offline
Boat: 78 S&S, 04 Pro 209
Wow, I read up to Pg 5, and at that point I was looking at the BW R3098 relay making up dual battery set-up.
The specs don't indicate it's a latching relay. I suspect it's general purpose starting relay.
Wouldn't latching be preferred? Vs a constant draw/drain on the Batteries.
Current research - Amazon $63 - advanceautoparts - $43
Other - SD SERIES 7800
Old 05-29-2012, 07:56 AM
bturner2 bturner2 is offline
Don't know the answer to your question but I can tell you I'm on my fourth season with the Blue Seas "add a battery set up" with no issues. Easy install, all parts tested/included, no questions needed or answers required. Best of all it works.
Old 05-29-2012, 09:21 AM
Sodar's Avatar
Sodar Sodar is online now
Boat: '07 ProStar 197 w/ MCX
X2.... Works great!
Old 02-05-2013, 09:32 PM
51timber's Avatar
51timber 51timber is offline
Boat: 2003 X30
Quick question on fuse sizes??? What size circuit breakers are most running from the islator to the battery for both the starter side and the house battery side??? Also if I go from a 70 amp alternator is it really necessary to change all of the associated wiring??? I have seen through this thread so many different opinions my head is spinning. What is the consensus?
Old 02-06-2013, 11:46 AM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
The Blue Seas Add-A-Battery installation guide has some guideance on wire sizes and fuse sizes. There is also a URL to a calculator in those instructions that should help with wiring sizes:
https://bluesea.com/files/resources/.../990310020.pdf
