Old 02-05-2013, 06:30 PM
Matt555 Matt555 is offline
Boat: Mastercraft prostar 190 1997 lt1
Thumbs up Best prop for mastercraft prostar 190 lt1 with 1.5-1
Hi- I recently bought a mastercraft prostar 190 1997 with lt1. It had a 13x13 prop with a top speed of 32mph at 5500rpm.
I believe the transmission is 1.5-1.
I want an all round prop for slalom, barefoot and wake boarding.
Any help appreciated?
Matt
Old 02-05-2013, 08:04 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Matt
Hmmm, something is definatly amiss, first you will need to verify exactly which transmission you have, a 13x13 is oem for a 1:1 and a 14x18 is for 1.5:1, your best bet is to contact Acme propellers (888-661-ACME) or OJ propellers (800-359-9730) and ask the experts.
/spôrk/
Old 02-05-2013, 09:16 PM
strad's Avatar
strad strad is offline
Also mike your shaft before you call. I know the earlier powerslots like mine have a bigger shaft (1 1/8th instead of 1 inch). It'd be nice to know that everything forward of the prop is powerslot spec on your boat before you try to order a correct prop for it.
White with blue stripes. purchased 9/2012
Old 02-05-2013, 10:13 PM
petermegan's Avatar
Definitely need to confirm transmission ratio and also a gps confirmed speed first. Have fun.
Old 02-06-2013, 12:59 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
That is a good point about GPS confirmation. Are you going off of the boat speedo? I wouldn't think that the speedo would be off by 12-13mph, but anything is possible and a less expensive fix if that is the case.
Old 02-06-2013, 01:06 AM
Spork's Avatar
Boat: Sporkcraft
Not to mention the 5500 rpm's, seems a bit much its over spinning the prop by a huge amount.
/spôrk/
Old 02-06-2013, 07:27 AM
Thanks to all for replies. Shaft is 1"1"8 and have verified with my gps that speed is correct.
5500rpm is 32mph top speed. Gearbox is 1.5-1.
What sort of top speed will I expect out of 14x18 prop James? Will it still give me plenty of power take off?
Cheers matt
Old 02-06-2013, 07:56 AM
petermegan's Avatar
I am running a 14*17.5 ACME but don't ask the number. same ratio trans as yours. Standard 14*18 was similar although didn't perform quite so well in all areas. Better speak to a prop expert, someone has wrongly propped that boat by a mile! I have been tempted to talk to ACME about gearing. Mine is doing pretty close to 3900revs at 36mph which is a tad underpropped for my liking and use. I would personally prefer 3600revs at 36mph. Top speed is a measley 43/44mph with the LTR330 indmar. Have fun.
Old 02-06-2013, 08:09 AM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
Something still isn't right about those specs...
But if they are... Can you imagine the take-off being that badly under propped? Would literally rip your arms out of their sockets
Old 02-06-2013, 08:41 AM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
The numbers sound right with a 13 X 13 on a PowerSlot trans. I would suggest trying our 13.7 X 17.5 LC 1 1/8" XMP 4-blade.
Eric Johnson
Johnson Propeller Co., Inc
ojprops.com
800-359-9730
