Old 02-04-2013, 06:52 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
Pix and Thanks Again
Okay guys--I'm not an expert at this so bear with me. Also, shooting photos under the dash with all the spaghetti made for some tricky lighting.
First, modified the batter cover a la Sodar's install:
Then, ran custom terminated wiring (did my own but I have a tool just for compressing lugs onto cable--2 Gauge in this case.
Here's one part of the install that I could use some other ideas on. Currently, the wires to the House Batt/Isolator run forward from the starting battery and then through the cutout for the heater duct. I did sleeve the cable in plastic loom so that the fiberglass edge of the heater access cutouts won't damage the softer insulation on the cable. Any ideas of alternate routes?
At any rate, here's the isolator as suggested by Diesel--mounted on the bulkhead near the other electrical bus bars. Positive in/out secured with nylocks. Signal cable tied to the ignition key and ground for relay activation:
And finally, the overkill billet holder and streetwire clamp (ground side shown). A bear to get it in there and I will be adding a battery maintainer for just this unit--taking Sodar's sage advice so that I don't have to wrestle that thing much:
Old 02-04-2013, 08:26 PM
MCOCD@13 out of 10
okay - that's a nice project...well done!
Old 02-04-2013, 08:28 PM
Very nice job.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 02-05-2013, 08:07 AM
bturner2 bturner2 is offline
Nice post.
Old 02-05-2013, 10:26 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Looks good. There is a chase from the battery box, under the floor and then over to the dash if you want to get the aux battery cables hidden.
Old 02-05-2013, 07:40 PM
Kweisner's Avatar
Thanks Sodar. I see the original cables from the batt to the dash bus bars going into a chase but could not figure out how to fish it through. I need to give that another go when I'm more patient--I know it will look neater!
Old 02-05-2013, 09:08 PM
Boat: 2002 Prostar 209 - SammyD Edition
use a fish tape or coathanger. Make take a few tries. Fish tapes are cheap for short ones and well worth the $ if you are going to work on the boat yourself.
