  #2351
Old 01-31-2013, 05:29 PM
psychobilly's Avatar
Originally Posted by Lumbergh View Post
Finished up new coil install.
Vacuumed.
Changed Oil and filter.
Yes, I am aware poly belt is slack. Replaced with new and have not tightened, keeping tension off of it for the winter.
I see you scored some of that nice looking Trident hose too 😉
Oh and something that I did when I changed my belt is I took the old one and left it on and wrapped around the water pump, then zip tied it. Just in case my belt breaks while on the water I have a back up ready to go.
Old 01-31-2013, 06:16 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - 350 MCX
Originally Posted by KahunaCraft View Post
I'm working on adding one of these, likely the first of it's kind from SideShift...
Attachment 89323
What drives this? Is it an electric motor?
I think trying something new is cool. Good for you. I bet you'll be purposely pulling to the dock at 90* so you can engage that and swing yourself around.
For me... I don't think I'd add it to my MC.
Hope it works out for you, and your time and money spent is worth it.
Jeff
Old 01-31-2013, 08:59 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Delete
Old 01-31-2013, 11:44 PM
ProStar200's Avatar
ProStar200 ProStar200 is offline
Boat: 1990 Prostar 200 Outboard
Can't wait to see the progress.
Old 02-01-2013, 10:25 PM
catamount catamount is offline
Boat: 1987 Prosport 190
My MC has been wrapped for a couple of months now but I did take some parts off to play with this winter.
I took my crank pulley off, blasted it and powder coated it in my home powder coat setup.
I also rebuilt my Johnson water pump. This thing was spray painted black and looked terrible. It also leaked like crazy. I got a new seal from skidim and it seems to hold water now in an unscientific sink test.
I took a wire wheel to the body to clean off the old ugly paint.
Then blasted & powdercoated the bracket, replaced the rubber grommet and put it back together with a stainless bolt. It's as good as new.
See my on-going 1987 Prostar 190 "project" thread here!
Old 02-01-2013, 11:11 PM
MC Platinum
Nice work catamount
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Steel and galvanized wheels available.
Old 02-02-2013, 12:58 PM
mwg's Avatar
mwg mwg is offline
Boat: 2001 Prostar 205V
I changed the steering cable out on my 205v. Relatively easy job except I had to remove the middle floor section to pull the cable past (& back through)by the front of the . also my MCOCD kicked in and I had to clean fuel tank and the area under the floor. Now I turn the wheel with a finger as opposed to wrestling with it.
Old 02-02-2013, 04:09 PM
MC Platinum
Originally Posted by mwg View Post
I changed the steering cable out on my 205v. Relatively easy job except I had to remove the middle floor section to pull the cable past (& back through)by the front of the . also my MCOD kicked in and I had to clean fuel tank and the area under the floor. Now I turn the wheel with a finger as opposed to wrestling with it.
Very rewarding project. It is amazing how much nicer it is to drive with a fresh steering cable. If I even think my steering is getting stiff again I will throw in a new cable.
- Peter
TIRE & WHEEL SALES
Old 02-02-2013, 06:05 PM
Boat: 2002 Prostar 209 - SammyD Edition
Steam cleaned every inch of carpet in the boat
Buffed and waxed the interior while its out for new skins.
My arms hurt from removing 11 years of funk behind the seats.
Think MCocd has hit an all time high. I even scrubbed the gas tank today.
Old 02-02-2013, 06:14 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Nice. Teamtalk = Enablers.
