#2351
Oh and something that I did when I changed my belt is I took the old one and left it on and wrapped around the water pump, then zip tied it. Just in case my belt breaks while on the water I have a back up ready to go. |
#2352
I think trying something new is cool. Good for you. I bet you'll be purposely pulling to the dock at 90* so you can engage that and swing yourself around. For me... I don't think I'd add it to my MC. Hope it works out for you, and your time and money spent is worth it.
Jeff |
#2353
Delete
#2354
Can't wait to see the progress.
#2355
My MC has been wrapped for a couple of months now but I did take some parts off to play with this winter.
I took my crank pulley off, blasted it and powder coated it in my home powder coat setup. ![]() I also rebuilt my Johnson water pump. This thing was spray painted black and looked terrible. It also leaked like crazy. I got a new seal from skidim and it seems to hold water now in an unscientific sink test. I took a wire wheel to the body to clean off the old ugly paint. ![]() Then blasted & powdercoated the bracket, replaced the rubber grommet and put it back together with a stainless bolt. It's as good as new. ![]() ![]()
See my on-going 1987 Prostar 190 "project" thread here! |
#2356
Nice work catamount
#2357
I changed the steering cable out on my 205v. Relatively easy job except I had to remove the middle floor section to pull the cable past (& back through)by the front of the . also my MCOCD kicked in and I had to clean fuel tank and the area under the floor. Now I turn the wheel with a finger as opposed to wrestling with it.
#2358
#2359
Steam cleaned every inch of carpet in the boat
Buffed and waxed the interior while its out for new skins. My arms hurt from removing 11 years of funk behind the seats. Think MCocd has hit an all time high. I even scrubbed the gas tank today. |
#2360
Nice. Teamtalk = Enablers.
1991 ProStar / 351W with 1:1 Velvet Drive |
