Old 11-13-2012, 02:07 PM
1redTA's Avatar
1redTA 1redTA is offline
The silver pan under the crank is a windage tray
1981 MasterCraft
19' Skier 351W PowerSlot
Old 11-13-2012, 03:34 PM
Hogwild's Avatar
Hogwild Hogwild is offline
Boat: n/a
Originally Posted by gweaver View Post
What's that silver tray visible under the crank when the oil pan was removed? What's it for? The few times I've pulled an oil pan off an engine, I've never see one of those.
G
My buddy had never seen one either. I guess it's to avoid oil being sloshed around with all the vibration and bumps that a boat takes.
Old 02-02-2013, 01:29 AM
Hogwild's Avatar
Boat: n/a
So i had some extra carpet left over after doing the rear compartments and was thinking about redoing the main visible areas in the boat. Does anyone have a link for removing the floor around the gas tank? I want to see just how hard of a job this may be.
Old 04-03-2013, 08:57 PM
Hogwild's Avatar
Boat: n/a
I thought I would post some update pictures. I want to thank you guys for all your input and especially BrianM for helping me pick out the right products to go with since this was my first try at oxidation removal.
Old 04-03-2013, 09:02 PM
Hogwild's Avatar
Boat: n/a
Here are the after photos. It took a long time but it was well worth it. Only negative is I lost the Mastercraft sticker on the back because I was trying to get down to previous owner's decal and remove any trace of it. I'll try and get some better pics once the sun actually comes out.
Old 04-03-2013, 09:15 PM
Big tic Big tic is offline
Boat: 2009 Mastercraft x45
what products did you use to remove the oxidation?
Old 04-03-2013, 09:20 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Looking good. Great work.
Old 04-03-2013, 09:31 PM
Hogwild's Avatar
Boat: n/a
3M super duty rubbing compound and a wool pad on a rotary polisher. I was a little nervous that I would burn through the gelcoat pretty easily with the rotary, but I have to say that it was harder to cut than i thought. I just kept the moving the rotary around and made several passes.
Followed it up with 3M finesse it, but really all the cutting was done and this just seemed to remove any small scratches that may have been left from the wool pad.
Old 04-04-2013, 06:47 AM
TN Barefooter's Avatar
TN Barefooter TN Barefooter is offline
Boat: 2015 Mastercraft NXT "Plum Loco"
Nice work, you really did a great job on removing the oxidation.
Old 04-04-2013, 08:55 AM
What a huge difference. A lot of work but the results are well worth the effort.
