  #111
Old 01-29-2013, 07:12 PM
MCOCD@13 out of 10
did you mean the pressure shock hold up the box things?
Old 01-30-2013, 03:45 PM
Worthing skier's Avatar
Boat: mastercraft prostar 190 1993
Hi Mike G
Yes I need to order a pair the gas rams to lift the engine cover box,
but my local dealer needs to know the length when fully extended,
I think they are 30".
Update on the rest of the project , not moving ahead much as the block is being bored and I am waiting on the pistons , bearings, inlet valves and gasket set , so I am trying to sort a few trim bits.
Kevin
Old 01-30-2013, 04:06 PM
02ProstarSammyD 02ProstarSammyD is online now
Boat: 2002 Prostar 209 - SammyD Edition
I thought they were 20 ext, 12 compressed
http://www.mastercraft.com/teamtalk/...ad.php?t=35684
Old 01-30-2013, 09:42 PM
MCOCD@13 out of 10
I'll get the part number off my '95 and post tomorrow.
Old 01-30-2013, 10:20 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 1994 Prostar 205
Here is the model that I have on my 94. SPD-GSNI-5300-60. 20" when extended and 12" compressed as Sammy said.
http://www.ebay.com/itm/Gas-Spring-S...-/350301239199
Old 01-31-2013, 03:34 PM
MCOCD@13 out of 10
^^ - what I have...
Locally for you ... http://www.goldrv.co.uk/parts/produc...as-springs-20/
Old 02-02-2013, 05:12 PM
Thanks Mike G
Got them from my local MC dealer @ £8.00 each , bargain.
Checked the fuel pump , powered it up and appears to run up fine , so unless it does not give enough pressure it should be okay .
Old 02-02-2013, 05:17 PM
Fuel hose route
Forgot to ask ,
Re the main fuel hoses to and from the fuel tank , do they normally run behind the tank or in front .
thanks
Kevin
Old 02-02-2013, 05:31 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Originally Posted by Worthing skier View Post
Forgot to ask ,
thanks
Kevin
Behind and under on my machine.
Old 02-06-2013, 04:24 PM
Wiring loom
Hello all
Hopefully an easy question this time ,
On the rear wiring loom for the fuel tank sender unit the is a plug/socket with 3 wires
black , pink and green ,
Black and pink are for the tank sender , I am not sure re the green wire , possibly a ground wire for the fuel filler neck but not sure .
Any advice on this.
thanks
Kevin
