Old 02-27-2012, 02:35 PM
mramerman@gmail.com's Avatar
mramerman@gmail.com mramerman@gmail.com is offline
Boat: current: 2010 X14v, 350MCX - former: 1997 PS190 w/ LT1
Originally Posted by BrooksfamX2 View Post
Where is that??
Lake Entiat, Columbia River, North of Wenatchee in Eastern Washington (State).
Old 05-31-2012, 12:00 AM
kentcunningham's Avatar
kentcunningham kentcunningham is offline
Boat: 2003 X9
any pics of the slalom wake behind the X14V? Thanks much.
Cmon...lemme just push one button...
- Red X9 on Center Hill & Old Hickory lakes in TN -
Old 05-31-2012, 01:51 PM
Slalom wake at 34 mph
Sorry, photos taken portrait on iPhone get turned landscape by this system. Not the best photo, but you can get a sense. I will take more next time I am on the water.
Old 09-09-2012, 11:24 PM
Boat: 2003 X9
That's actually really sweet. Much better than I expected. Tha ks for the pic!
Sent from my Lumia 900 using Board Express
Old 01-30-2013, 12:40 PM
rtw_travel's Avatar
rtw_travel rtw_travel is offline
Boat: 2012 X-14V
Originally Posted by mramerman@gmail.com View Post
Thanks. Yes.
Happens generally with a hard pull by the rider. It shifts pretty frequently.
Sorry to dredge this one up and I realize the thread a year old... but do you remember the speed & line length in the wakeboarding pics? I'm just learning to drive for wakeboarders, and I've been reading about the 'sweet spot' for boarding, where the line length is just a bit in front of the wake curl. It would be good to know a starting point for my x14V when I get back in the water this summer.
And a question for the boarders...
Its hard to tell because the wake is not symmetrical, but it seems the curl is way behind the rider in these pics? or would the curl move closer to the boat if the wake was made symmetrical again?
Thanks
2012 X-14V, 5.7l Ilmor MV8, A plate, pro package w/ ZFT-2, heaters, stock everything else.
Old 01-30-2013, 12:59 PM
Boat: 2002 Prostar 209 - SammyD Edition
Depends on weight etc. Different people ride at diff speeds and lengths. I have a few people in my boat that ride at 19.5 and some that ride at 23. All about what the rider is comfortable with along with skill level. Same can be said for rope length. Typically beginners ride a lil shorter when starting jumps etc b/c your crossing is narrower. If someone doesn't know what speed to go I start them at about 19 and let them tell me faster or slower. You can adjust the speed on your perfect pass during a run. Way too many factors depending on your setup.
Also consider how you want the wake shaped. More front weight is going to make the wake rampier and more weight in the back makes it steeper.
Also not sure if/which version of PP you have but on alot you can set up different riders and save the settings so they don't have to remember.
Old 01-30-2013, 04:06 PM
Thanks
The rider in the photo is at 55' and 20 mph ish. The curl is generally gone when the boat / ballast is dialed in a bit better. Those photos are from my first season with the boat !
Old 04-28-2013, 11:48 PM
swivelina
Guest
Boat: x-14v
Posts: n/a
Is your wake pretty much always washed out on the driver's side or have you figured out how to control it?
Old 04-29-2013, 05:52 AM
^my guess is he needs more weight and its washing out on each side opposite of the rider. My x9 does the same with no ballast if the boat is low on people.
