Old 01-27-2013, 10:00 PM
bryanc bryanc is offline
Boat: MC, X1, 2007
07' X1 Cruise issues
My cruise has worked great for years, but a couple of years ago we started having issues with it. I will set it and bring up to speed and it will take over fine, but then the boat will start to surge and not maintain speed until it settles at an idle, almost like I'm having a fuel issue. In fact that's what we thought it was, but were able to narrow the issue to the cruise (once it starts doing that we can turn the cruise off and it will run fine). So far I have not been able to figure out a pattern or symptom, it seems to happen completely at random. It will run great for a few tows then will start up again. I talked to the shop at my dealer and they thought it might be a speed paddle issue, but speedos seem to work fine when this is happening. Any thoughts?
Old 01-27-2013, 10:16 PM
Boat: 2006 X30
MasterCraft cruise or Perfect Pass?
Old 01-27-2013, 10:56 PM
sand2snow22's Avatar
Boat: MC
Bad ground? Pop the MC cruise off the dash and make sure the connections behind are tight. Also make sure those same wires are connected well in the engine compartment. Probably need a wiring diagram for that.
www.nwboatsports.com
Old 01-28-2013, 04:52 PM
Boat: MC, X1, 2007
mc cruise control
It is the mc cruise control w/ a toggle for mph and rpm.
Old 01-28-2013, 06:40 PM
bobx1 bobx1 is offline
Boat: SOLD 2007 X1
Does it happen in BOTH RPM and MPH mode?
Old 01-28-2013, 10:40 PM
Boat: MC, X1, 2007
Yes both rpm and mph
Old 01-28-2013, 10:42 PM
Boat: MC, X1, 2007
Sand2snow- That does sound like a possible culprit, my only problem is in S. Oregon I'm still a couple months from taking the boat out of the garage and putting it on the water.
Old 01-29-2013, 12:27 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 1994 Prostar 205
Check the paddle wheel, if you have not already. While I do not think this is it, worth a look. Mine does the same thing even after a reset. Still have not figured it out, although it seems to work better in RPM mode than wakeboard mode.
