#141
Ordering mine right now! Got to keep the ole girl updated!
#142
Long push from OFF, ACC, or ON will engage the starter. To re-engage the starter, you have to drop back to OFF or ACC first.
Since there is no "engine running" signal, the control module assumes that the engine is running if the starter has been engaged (even just momentarily). This prevents you from engaging the starter again unless it is cycled to OFF or ACC. The video isn't a complete demonstration. I made that last summer just to show a friend which is why I didn't actually start the boat and go through all of the sequences. I'll make a more complete video once I de-winterize .Quote:
#143
I have the long-push to OFF change working and tested.
So, now while the engine is running, a single momentary push will kill the engine and put you in accessory, or a long push greater than 2 sec. will kill the engine and go directly to OFF. |
#144
Nice damage prevention feature. Thanks for the explanation. ![]()
Jeff |
#145
I saw the $15 shipping and wondered how you ship these?
Jeff |
#146
Ordered mine as well, is there any sort of order status or ability to check shipping? Not that it's a big deal as I don't have the boat home with me but just wondering.
Thanks!
1996 ProStar 205 |
#147
You should get a notification when it is shipped but you can always email me for a status. |
#148
Thanks to everyone who has ordered.
The first orders are going out Tuesday via priority mail, so you should start seeing them arrive soon. |
#149
After some careful consideration, I decided to make a few changes to the function of the push-button starter. These changes are intended to make starting the boat a more deliberate act and also to improve security.
So, you will only be able to start the boat when the ignition is ON, not from OFF or ACC. Also, instead of a toggle cut-off switch, you will need to use the original key-switch as the cut-off switch. These are minor changes, but I just wanted everyone to be aware of the changes since it is slightly different than I quoted before. |
#150
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
