Wondering Aloud - rear fiberglass boarding
So, somebody smart - what if you took the rear center motor box covers on all our older 205v's, x1's, xstars (most popular hull ever made) - and made a fiberglass boarding piece to replace the existing vinyl and foam. Then, it would be similar to the newer boats in that when you needed to board from the rear, you walk across a fiberglass (nice molded traction, you could add SeaDeck, whatever) instead of the foam. If done right, you could mold the sides so it drained back towards the rear). Again, just the center rear - keep the foam/vinyl on the sides.
I would think this would order out pretty well. I'd be in. |
We use ours as a sun pad, so it need to have a pad in the middle for those times also.........
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
Jim at Viper is doing a walkthru on mine. Basically the center sunpad will get divided into 3 parts, the center being the walkthru. Then he is going to put sea-dek on that walkthru area. It will also have a cushion to fit over the walkthru when we want to use the whole sun deck.
Give me/Jim 5-6 weeks and you all will be able to...lol
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
yes, want to see this for sure.
