Old 08-31-2012, 02:59 PM
XStar08's Avatar
XStar08 XStar08 is offline
Retrofit Zero Off in XStar 2008
Hi, that is my first thread, have been following that board for a while now and decided to start contributing as well.
Just bought a used XStar 2008. Pics will follow. Years ago I owned a 91 ProStar 190 which I completely restored and put new electrics in it.
Well, I would like to add Zero Off to my XStar. Does anyone know if that is a big story and whether it will be completely integrated in the system?
Thank's for your help, xstar08
Old 08-31-2012, 03:40 PM
Ole Miss Rebels's Avatar
Ole Miss Rebels Ole Miss Rebels is offline
Boat: 2008 X-Star, Red and Black, L18
i have an '08 xstar and of course it has the vdig display with the perfect pass integrated into the vdig. my perfect pass works really well. i had to call perfect pass and give them my boat year and model, engine and transmission, prop, amount of ballast and normal driving speed and they told me how to set the three adjustible parameters (can't remember the abreviations for them now. maybe cs, nn and ??). i would consider trying to adjust my perfect pass and get it dialed in before i would embark on zero off. good luck.
"Tropic corridor, tropic treasure. What got us this far to this mild equator? We need someone, something new....something else to get us through" (James Douglas Morrison/The Doors)
Old 08-31-2012, 03:52 PM
XStar08's Avatar
That of course is an option but however I would like to know IF and if yes HOW Zero Off could be retrofitted.
Regards, XStar08
Old 08-31-2012, 04:07 PM
i believe i remember several threads that were lengthly when zero off first came out. if i am not mistaken i believe there is a simple plug and play zero off but i don't believe it was able to be integrated into the vdig. hopefully i am mistaken and surely many on here can help you further. also, maybe you can email zero off and they can tell you. good luck.
Old 01-19-2013, 02:09 PM
XStar08's Avatar
Well, I'm still thinking about that...
This is a good source, unfortunately it seems not to be too easy to retrofit:
http://www.mastercraft.com/teamtalk/...p/t-27486.html
Will have to check out now what kind of controller I have aboard.
Old 01-19-2013, 04:59 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
I think there are four options : just listing them in case you haven't seen them...
1. Tinker with the configuration, suspect perfect pass folks or someone here might have the right or a better config.
2. Cheaper paddle wheel GPS replacement
http://nauticlaugic.com/
3. Perfect Pass Stargazer upgrade
4. Zero-Off
Old 01-20-2013, 03:17 AM
XStar08's Avatar
My PP is working ok, probably not anymore with more weight in the boat.
Options 2 and 3 are none for me. No. 3 would not work since they programmed the PP feature into medallion software box.
I would like to have a gps based speed and I think I will have to change also the controller box to be able to communicate with ZO. That should be possible since you could order your boat these days with the ZO option or without it...
Old 01-20-2013, 03:19 AM
XStar08's Avatar
Old 01-20-2013, 01:49 PM
moleson10's Avatar
moleson10 moleson10 is online now
Boat: mastercraft, 197, 2006
You may already know but at lower speeds (i.e. surfing) using RPM on PP works much better than speed. That combined with a hand held GPS works quite well.
2008 40th Xstar
2006 ProStar 197 - sold
1992 Ski Nautique
1969 Glastron
x star 2008, zero off
