Old 01-15-2013, 10:33 AM
corey's Avatar
corey corey is offline
Boat: between boats
The weights were updated on MC boats across the board, the way I understand it the boats are built using more fiberglass (especially resin) than engineering had figured so while the 197 didn't change the posted weights were a bit lower than the actual weights.
Technically the ILMOR engine weighs a bit more due to it's cast iron exhaust manifolds, the block itself if the same so no difference there block to block. The 6.0 liter does weigh more than the 5.7 and likely more than the 03' 6.0 (the 03' was an LQ block, in 07' this was swapped for a full cast LY block).
Not sure on the platform height, technically these two boats use different platform brackets but a 197 platform sits in the same spot on the hull across all years (at least as I recall).
Final difference would be the prop. I know swapping the prop on a 5.7 Liter TT has a pretty big effect on the wake.
Old 01-15-2013, 12:11 PM
jwroblew's Avatar
jwroblew jwroblew is offline
Boat: 2003 x7
Originally Posted by corey View Post
...Technically the ILMOR engine weighs a bit more due to it's cast iron exhaust manifolds, the block itself if the same so no difference there block to block. The 6.0 liter does weigh more than the 5.7 and likely more than the 03' 6.0 (the 03' was an LQ block, in 07' this was swapped for a full cast LY block).
I think a 2003 would still have the cast iron manifolds as well. I don't think Indmar went aluminum until around 2005 or 2007.
Boat - '03 X7 with '10MCX and ZO
Ski - D3 X7
Web Site: http://www.lakeswerve.com
Old 01-15-2013, 12:25 PM
corey's Avatar
Boat: between boats
You're right, the 03 would have been cast iron. I haven't weighed them both so not sure about the differences in weight between those and the ILMOR manifolds.
Old 01-15-2013, 12:46 PM
Ryan's Avatar
Ryan Ryan is offline
Boat: 1993 Prostar 190 285hp HO
I'm put my money on resin and the engine as the causes for change in stated weight.
I like Doo's theory on the tower leaning the boat forward. The vinyl is thickerm but I doubt that adds a net increase of even 30lbs.
Choose The Right
5mph>Wakeless Speed>32mph
Old 01-15-2013, 03:55 PM
AussieMC's Avatar
AussieMC AussieMC is offline
Boat: Mastercraft prostar 197 tournament team 2003, 310 predator, zeroflex mini tower.
It's very interesting that they have added more resin/fibreglass, I remember around 2007 there was a rumour/talk about they had actually lightened the hull.
The tower could have a minor impact (I'm not sure how much weight is in a mini tower) but the weight from the tower is essentially over seats section of the hull, so the effect forward or back would be minimal.
I have updated my platform brackets to the Alloy fold down, so that eliminates that variable.
The vinyl overall, and padding around the gunnel's etc. is thicker, but I agree, there may be only 30lbs there.
I was just curious about the wake/weight difference in an essentially 10 year unchanged boat.
Old 01-15-2013, 04:20 PM
rodltg2 rodltg2 is offline
Boat: SN196
Send a message via AIM to rodltg2
I don't think that the wake variation is solely affected by stated weight difference whether its accurate or not. It has do something with the hull and mold. There is no way each boat, especially from 10 years ago, comes out exactly the same.
Old 01-15-2013, 06:51 PM
JohnE's Avatar
JohnE JohnE is online now
Boat: A 2009 X14
And ther was a rumor (maybe true) that some of the molds perfomed better than others. At least years ago.
'97 Prostar 190 - LT-1
Old 01-15-2013, 08:57 PM
rhsprostar's Avatar
rhsprostar rhsprostar is offline
Boat: 04 TT 197
From what I understand, there are at least two different molds for the 197 and although there are supposed to be identical, in reality they turn out two slightly different hulls. Supposedly one has better slalom wake than the other..........so I've heard......
04 197 TT LQ9 stargazer w/Z-Box
PB 1@35off
Previous...
96 Prostar 205 Lt1
93 Prostar 205 HO
81 Leaves and stripes(Can. edition)
Old 01-15-2013, 11:41 PM
Boat: SN196
Someone needs to toss the bad one then.
Old 01-16-2013, 02:58 AM
blackTT blackTT is offline
Boat: 08 tournament team LYR6
Possibly could be all the sound suppression they now run in the boats to keep them quieter....... The new models are a million times quieter then the earlier rattlers.......
