Old 01-14-2013, 06:34 PM
WindBraker
Guest
Boat: 197
Posts: n/a
197 ?
Hey guys. I'm about to pull the trigger on a 5 year old ps197. This will be my first ski boat. The boat is in excellent condition...very clean. One thing it does not have is 0 off or perfect pass. Do you think this will be a big deal? I haven't skied since I was a teen (now in my 30's) but plan on skiing my brains out once I get the boat.
Also, any words of wisdom, or thoughts on the 197 will be appreciated.
Thanks in advance for your input.
Old 01-14-2013, 06:37 PM
AussieMC's Avatar
AussieMC AussieMC is offline
Boat: Mastercraft prostar 197 tournament team 2003, 310 predator, zeroflex mini tower.
If it's 5 years old, 2007? you wont be able to fit Zero Off, but you can put in PP stargazer. The pull will be a lot more consistent and you will enjoy your skiing more, + it makes it easier for the driver. 2008 was the first year of Zero Off, but it is not necessary unless you are going to tournament ski.
Old 01-14-2013, 06:48 PM
MCOCD@13 out of 10
If you have some extra cash just have it installed after the fact. I don't have it wish I did - a friend doesn't have wish he did. It also depends on your level of skiing... just getting back in...unless your slowing the boat down on the wake cross - get it next season IMHO...
Old 01-14-2013, 06:49 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Not a deal breaker and an easy add on down the road. The boat should have MasterCraft Cruise, as I believe it was standard in '07. Either way, use it for a while and see if you need/want to get Perfect Pass.
Old 01-14-2013, 06:54 PM
Boat: 2002 Prostar 209 - SammyD Edition
Stargazer is great! Its alil $$$ but well worth it however I can't compare to the stock cruise as I've never used it
Old 01-14-2013, 06:55 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: 2003 35th Anniversary LQ9 Supercharged
I have have 3 Event Prefect Pass and all it does is piss me off!!!
Old 01-14-2013, 08:51 PM
TayMC197's Avatar
TayMC197 TayMC197 is offline
You piss me off 03!!
Old 01-14-2013, 09:09 PM
Old 01-15-2013, 09:19 AM
stargazer?
Old 01-15-2013, 09:35 AM
Tricky1 Tricky1 is offline
Boat: 1999 Mastercraft ProStar 190, LTR1
If you are a serious tournament skier, go with a boat that has Zero Off. The slalom pull is a lot different than Perfect Pass StarGazer, for slalom. Zero Off is GPS based, and PP StarGazer is RPM based. I had the Perfect Pass in my 2002 197 TT, but have the Zero Off in my 2010 197 TT boat. For tricks either one is fine, although Zero Off gives a better pull and can provide a more custom pull due to the letters (A, B, C) and numbers (1, 2, 3) option. Those same letter/numbers combination are also available for slalom and jump. Perfect Pass does not offer those customized settings. A1 is the softest pull, and C3 would be the strongest pull. If you are not really a serious tournament skier, then the Perfect Pass StarGazer is a great speed control. The Zero Off pull for slalom and jump, is a lot different than PP StarGazer.
