  #2251
Old 01-13-2013, 10:54 AM
gatorguy's Avatar
gatorguy gatorguy is offline
Boat: 1997 PS205, x-14 someday
Finally finished my winterization. I had drained the block, but had still intended to use he boat well into November, but never got out after Nov. 1st. It was nice to be in the boat again, even if it was just in the driveway hooked up to the hose.
Also starting to plan my garage. I'm thinking something on the line of 40x50' with a 12' door. Any one with recommendations on insulated metal buildings?
Old 01-13-2013, 11:01 AM
Table Rocker's Avatar
I'm not sure what type (red iron, web truss, wood) metal building you are planning, but if it is red iron there is a 20ft maximum between trusses. With that, a 40'x60' won't cost much more than a 40'x50' if you have room for it.
'96 ProStar 205 SD LT-1
Old 01-13-2013, 06:17 PM
ctjahn ctjahn is offline
Boat: Own a 78 MC S&S
Tanked...
Installed the gas tank today (after the new sending unit installed awhile ago)...
Cleaned up the wiring under the stern and covered it with a wire wrap. REMINDER: ROMEX, and HOUSE WIRE DOES NOT BELONG IN A CAR OR BOAT EVEN IF IT IS GOOD FOR 120 AC. AND MORE wire/connections isnt better in all cases... (removed a bunch of sht wiring, connections (no less than 10 with FOUR grounds; boy was it was a mess).
cj
Old 01-13-2013, 06:38 PM
MC Platinum
cj
I cleaned up a mess of wire and connections when I replaced my sending unit last summer. No romex, but three scotch-loks.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Steel and galvanized wheels available.
Old 01-13-2013, 07:54 PM
mustangtexas's Avatar
mustangtexas mustangtexas is offline
Boat: 1989 MasterCraft Prostar 190
Engineered steel buildings can have a 25' bay. We have one that is 40 x 80 with 20' bays and a 80' x 175 with 25' bays.
Old 01-13-2013, 08:20 PM
That is correct. I misremembered the criteria on my shop. I have 3-40x20s and a 40x25 on mine. My site was a little difficult. Thanks for correcting.
Old 01-14-2013, 09:29 AM
Wirin...
Crazy. The wire was looped upon it-self several times, I estimate about 10 splices, scotchloks, butt connectors, grounds on top of grounds, with a spliced ground..., wire twisted together and taped... The loom started out as about a 1" thick rats nest.... By the time I was done there were four wires...in a neat loom.
I cant believe the thing even worked!!! (sending unit and rear light!)
cj
Old 01-14-2013, 09:40 AM
Boat: 2002 Prostar 209 - SammyD Edition
Removed all the seats except for the from wrap arounds, pulled 10k staples out of seats, rewired my amps (what a freaking disaster it was before), built a new sub box, hooked up the new sub, changed to green impellers, put in new fuel sending unit, started scrubbing everywhere the seats were, and then finally sat down in an empty seatless boat saying "why did I do this?".
Does anyone know how to get to the bolts side panels in the bow? I've got all of them out except for the 2 on each side by the speakers. Can't go under to get them and my arms are too big to reach in through the speaker holes. GRRRRRR
Old 01-16-2013, 11:10 PM
51timber's Avatar
51timber 51timber is offline
Boat: 2003 X30
Removed all of the interior seats and panels and sent them to Jim at Viper customs.
Today replaced the Manifolds for the exhaust, installed new risers, new valve covers and gaskets. Installed a new ignition coil.
Old 01-17-2013, 12:06 AM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Wow...you have alot going on
---Animal house
