#61
Enter the strong stuff
This is the strong stuff.
#62
The repair is looking great so far! The gel will be pretty tricky to avoid having a halo. I will be interested to see how well it turns out. Where did you end up getting the gel from? |
#63
A really good friend of mine gave it to me. The only thing is if we use this on the bottom of the boat, it is harder than concrete, so it will be next to impossible to sand smooth. I was going to use the normal Poly resin on the outside and this on the inside. Also I will have to put the gel coat over the final patch as well. So I am going to want this as smooth as possible. Any thoughts.
#64
Hopefully this weekend we will have all the glass work done and next weekend we will start putting it back together.
#65
I sure do like the color of your boat
Rollin' Gangsta Style Quote:
#66
It is nice, isn't it?
#67
Thank you.
#68
Epoxy resin isnt "harder than concrete", though it doesnt sand especially quickly. Neither does poly, though. An angle grinder with a suitable attachment (like a flap disc) will make quick work of major high spots. A random orbital or palm sander can do the rest.
If you use the epoxy for the repair (as I would) then be sure to use a conversion coat (like vinylester) prior to laying gel, as it wont adhere as well directly to the epoxy. Im not sure you would want to do the repair in poly though... unless MC builds their hulls with it. I thought they used vinyl, but ICBW.
PCM 351w, 350hp Last edited by TRBenj; 01-11-2013 at 04:41 PM. |
#69
I like your idea better. Thanks again for the help.
#70
