Old 01-09-2013, 02:52 PM
jhtheo jhtheo is offline
Boat: powerstar 200, merc 200
powerstar 200 - engine replacement ?
would appreciate any and all thoughts on replacing the original 200 hp merc ?
currently, who makes the best 200/225 hp o/b for waterskiing (salt water) ?
thanks
Old 01-09-2013, 02:58 PM
aquaman's Avatar
aquaman aquaman is online now
Boat: 93 Barefoot 200 Yamaha 225F
Yamaha's are the best i have seen.
Several models to choose from, 2 stroke or 4 stroke.
Those boats were new w/the 200hp but they were acutally rated for 225hp.
Old 01-09-2013, 03:36 PM
thanks, that's where my research seem to be taking me... the merc has been extremely reliable, but parts and a reliable mechanic are becoming hard to find.
Old 01-09-2013, 04:18 PM
aquaman's Avatar
Be sure and have your transom checked for rot or stress cracks before bolting on new power.
When i re-powered my BareFoot 200 i also replaced the old hydraulic steering unit.
Old 01-09-2013, 04:28 PM
ProStar200's Avatar
ProStar200 ProStar200 is offline
Boat: 1990 Prostar 200 Outboard
No offence to the other Outboards out there but I am a huge fan of Johnson Outboards. I have three right now, a 225hp on the ProStar200 and I also have a 30hp and 9.9hp for my Zodiac Futura Mark1. Their line of E-TEC HO's are supposed to be incredible for performance and fuel economy. Check out BRP for their line of outboards. Good luck
Old 01-09-2013, 06:50 PM
Rockman's Avatar
Rockman Rockman is offline
Boat: 1995 Barefoot 200 Yamaha ProV 200, 1994 ProStar 190 LT1 1:1
The Evinrude E-Tecs are supposed to be really good but the Yamahas are supposed to be the best for salt water use.
Old 01-09-2013, 07:02 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 1994 Prostar 205
Well, when I worked for Chris Craft, we put on the Yamaha outboards, which I loved. They were put on our fishing boat lines. Mercury also makes a very good saltwater engine. It is supposed to be slightly faster than the Yamaha as well. The Evinrude/Johnson/Suzuki motors, from what I have read are great engines and low maintenance. My neighbor has a Johnson and I believe the only difference between that and the suzuki is the cowling. I think that whatever you decide to go with will be a good choice, as the four stroke engines have really come a long way.
Old 01-09-2013, 09:04 PM
VTJC VTJC is offline
Boat: MC, SportStar, 99, 350 310HP TBI,
If I was shopping for an outboard for a mature hull I would seriously consider buying a rebuilt one from http://www.oneoutboard.com/ Good luck in your search. Jamie
Currently Boatless, searching for next boat SN 196...?
Previous Boats:
99 MasterCraft SportStar CB
98 Moomba Boomerang 310 HP 350 Carb
88 MC PowerSlot 240 HP 351 Carb Black on White
Old 01-09-2013, 11:45 PM
mcparadise's Avatar
mcparadise mcparadise is offline
Boat: 1998 Sportstar 19/305 Chevy Indmar
thanks
Yamaha's current 4-stroke 200 hp starts at $15K. Ouch!!
Wouldn't go for the 2 stroke in saltwater. Been there and done that.
You could buy a pretty nice used direct drive for the same price, eh?
Old 01-11-2013, 09:42 PM
Boat: 1997 prostar 205 lt1
I've been running a 98 Yamaha 225 saltwater series 2 motor for the last 12 years. I use it offshore on a 22 ft Century center console. 850 hours of stone cold reliable use, best outboard I've ever owned. You won't hear many complaints about the fuel injected ox 66 two stroke motors except their thirst for fuel. I got around 10 gph fuel flow at 3800-4000 rpm and 20-22 gph at full throttle. They were actually pretty efficient at trolling speed because they shut off injectors below 1800 rpm. A four stroke will use about 1/3 less fuel but will cost you twice as much on the used market so you just need to run the numbers to see how long it takes to make up the difference. If you only go out once or twice a month it will take a long time to get the cost of the four stroke back but the four stroke will hold it's value better when you go to sell. If your merc was a carbed two stroke the fuel injected 225 will have the same or a little less fuel flow and will be a real torque monster with the 3.1 block. The 200 ox 66 yamaha is a 2.6 block and will get much better fuel flows than the merc.
