That deck rotated too far- I suspect that someone pulled the pin on the actuator and either accidentally let it flop back or the wind took it. It can't do that without one or the other- if you remove the pad and rotate the hinges, they'll match the gouges exactly. Keep it from moving too far, don't over-stuff the storage area and don't twist the deck. |
#12
But the point of my recent post was to try and figure out a way to prevent it from happening again. I've had the spots sanded down and re-gel coated. It looks like new now. But I'm trying to get it where it doesn't gouge anymore. Thus I thought about putting some rubber bumpers or some silicone back there to keep the sundeck from hitting the gelcoat again. If I leave it as is, someone could let it go back too far and it will gouge the area out again. |
#13
I'll try and post pictures later, but the boat is in storage. I don't think the screws were loose allowing excessive movement, but I haven't checked the gas shocks yet. I assumed the original ones were on there since the previous owner didn't change anything else.
Is there anyway to adjust the height of the actuator to restrict it from extending out all the way? Last edited by Hogwild; 01-09-2013 at 06:55 PM. |
#14
If the hinge is over rotating just a bit then how about grinding the hinge plate itself so that it has a concave recess. This should provide enough clearance if the is only slightly intruding into the gelcoat when the deck is fully opened. Would that work?
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot. |
#15
Maybe shift the mounting points for your struts or order some a little shorter with the same pressure?
#16
I suspect the end of the actuator attached to the deck and used to raise it was moved toward the stern. Disconnect the end of the actuator and reattach to the deck 6-10 inches closer to the bow. When fully extended it should not over rotate the deck so much that the hinges hit the stern deck.
#17
For climbing into the storage area when servicing, I used a rope with a clip to loop around the T handle or the bracket that could be moved. I then pass the loop on the other end of the rope over the ball on the pylon. The rope was cut to length so it won't let the pad open too far. |
#18
First, I think what everyone has said needs attention first. However, if you have access the the underside of the deck, you could add some glass and a piece of 1/2" wood around that area to help stiffen it up. I think this would help a little, but as long as the hinge is over rotating, you will still have the problem. Possibly a good place for a custom sticker? I know that would be covering it up, but it is really just a cosmetic thing and unless it over rotates to the point where it tears the glass, then keep on keeping on.
What about one of those rubber little round pads like those that are on kitchen cabinets to keep them from slamming to help prevent any gouging? Just a thought. |
#19
I was curious about those bumpers causing stress, but I thought it might protect in a worst case scenario situation and then just make a habit of not raising the deck all the way up. However, I couldn't get the bumpers to stick to the gelcoat so I'm wondering if a bead of silicone will work just as well. Regardless, I hope that I can find the source of the problem and not have to rely on anything else. |
