Keyless / Push Button Start - Winter Upgrade Promotional Price!
Need a winter project, how about a Keyless Push Button Start Switch!!
$89 winter upgrade promotional price for TT members I have one and it works great. TT member tr6courg makes them. http://www.wakeblaster.com/products/Push-Button-Starter Installation instruction link: http://www.wakeblaster.com/installat...tton-start-kit
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif Last edited by BrooksfamX2; 01-10-2013 at 09:59 AM. |
Pretty sweet! Work on an older pro star?
Tapatalk
1990 prostar 190, 351, powerslot 1.5:1, tinted windows |
Basically, its an electronic control module you mount remotely (under helm or dash) that replaces the key switch. All the wires that were on the switch are connected to the control module and a push button with LED light ring fits into the existing key switch hole.
The module has a cut-off switch that disables the push button. You can also wire the original key as the cut off switch if you prefer. I have just a standard toggle switch hidden under the dash that enables the push button start. That way when I leave the boat, I throw the toggle and no one will be able to start it unless they know where the switch is. The button toggles between OFF, ACC, ON then back to OFF. To start, you push and hold until the engine fires then one push to kill the engine and go back to ACC. In ACC, the ring light pulses (MacBook heartbeat style) and in ON the light is solid. Semi-related thread..... http://www.mastercraft.com/teamtalk/...h+button+start ![]() Last edited by BrooksfamX2; 01-09-2013 at 02:26 PM. |
I asked for one for Christmas, but Santa did not pull through. Maybe this discount will work out for my birthday.
Definitely on my To Do List, just not quite to the top yet.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
I really like the look and function of it and almost talk myself into getting one. The only reason I have not pick one up is out of safety concerns. Yes, I'm the old fuddy-duddy. I didn't know you could use the key as cut off switch with it so that does sound a lot better to me.
Can you turn the ACC on with the kill switch in the off position so the boat cannot be started accidentally?
Gone, surfing. |
My keys are in the ignition all the time too, but it seems more likely that someone might push a button rather then turn a key by accident is all.
Gone, surfing. |
#10
