Old 01-02-2013, 03:47 PM
46Chief 46Chief is offline
Boat: 2002 Prostar 209 "Tarbaby", 2001 Prostar 190 Donor "Holestar"
Can't figure out what the D is in the engine code and I don't have the injection system or cover to tell.
Hull ID# is: MBCDTMA2E202
Old 01-02-2013, 04:30 PM
I have a confusing designation in my hull Id too. Call MC they should be able to tell what was there.
Old 01-04-2013, 09:29 AM
Mine has it too. Would guess Duval
Old 01-04-2013, 09:45 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
Sorry for the threadjack- 02sammyD- what's the rational behind your boat having a mercruiser? Do you have a thread anywhere with pics/details?
Bailey
'02 X-9
Lake Blue Ridge
Old 01-04-2013, 10:18 AM
Any boat out of the duvall school had to run a merc due to a contract disney had. I haven't done a ton of investigating into the boat to be honest. It was sold out of orlando, then to rambo, then to the PO, then to me. The hours have matched down the line and the install is fairly clean besides the fact the use of faria gauges for temp and rpm so my assumption to this point is that its just an extremely rare boat. I've heard numbers of 10-30 total made. I can post some pics if you want. The engine is an 02 mag ski
Old 01-04-2013, 10:44 AM
D is for Duvall...DOH! Many surprises already in this project.
I e-mailed MC to see if I can get clarification on my Hull ID. Hope they respond today.
Anyone want to post an engine pic of their SD?
Old 01-04-2013, 10:51 AM
I can try and pop some later today if I can get out of the office
Old 01-06-2013, 09:37 PM
Was able to work on it a limited amount this weekend, mostly just started removing engine parts, and doing a little investigating. I removed the wire loom off the back of the engine and found that the bellhousing is stamped Indmar, I also found a small sticker on the oilpan that said LTR. I'm thinking this is an indmar LTR.
Removed the platform brackets, these are pretty aren't they? Look real close you can see the hull has a rubbr undercoat, maybe an antifouling paint. it doesn't look bad so it's at the bottom of the squawk list.
I'm curious why there's a chunk of cement bolted to the rudder.
The vinyl is pretty dirty in this boat, it is also worn. This wouldn't clean off with a have heavy application of soap and hot water. I thinking next winter we'll tackle interior replacement, since there are only a few minor holes and a couple tears in the upholstery. Has anyone tried to to dye or fix small tears and cracks with success?
Old 01-06-2013, 09:42 PM
VTJC VTJC is offline
Boat: None
The ‘cement’ is probably a zinc sacrificial anode on the rudder, to save the rest of the running gear. Looks like that poor boat slept in the salt water. Glad it’s getting a new life.
Currently Boatless
Previous Boats:
99 MasterCraft SportStar CB
98 Moomba Boomerang 310 HP 350 Carb
88 MC PowerSlot 240 HP 351 Carb Black on White
Old 01-06-2013, 11:26 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Wow. Nice find. Can't wait to see the progress. Hope you have some good luck with finding an engine for her.
